So I've got the Baleno motor in my vitara, finally fully functional, and workign through the bugs. The biggest one was the dizzy, in the end I'm running the factory baleno dizzy, machined and adapted to use the shaft and gear from a Vitara dizzy, and the vitara right angle drive/cam. It's running lean, and for the life of me I can't work out why. The fuel pump is a GOSS, more than capable of the flow and pressure, I've replaced the FPR, checked the position and function of the TPS...etc. Any ideas?
Users browsing this forum: No registered users and 158 guests
