| Engine Swap http://auszookers.com/forum/viewtopic.php?f=5&t=1231 |
| Author: | ookie [ Fri Aug 03, 2007 3:28 am ] |
| Post subject: | Engine Swap |
Hi I am new to this so here goes. I am about to undertake an engine swap on my 91' swb vitara replacing my g16a carbi to a g16b efi motor that i am extracting out of a 94' lwb. I have sourced a new fuel tank and lines understanding they are different needing an additional pump and high pressure fuel lines. My question is has any one out there preformed this engine swap and what problems may I expect to encounter and any suggestions would be appreciate. Regards Emma |
| Author: | robbo [ Fri Aug 03, 2007 3:36 am ] |
| Post subject: | Re: Engine Swap |
try getting hold of sp1086 he has done the g16b convesion on his vit |
| Author: | sp1086 [ Fri Aug 03, 2007 1:08 pm ] |
Yes been there done that... NOW LISTEN UP!!! If your going to do this yourself / backyard it. I cant stress this enough so here it is in CAPS.. Try to see it all in the vehicle b4 you but it. Yeah get a efi fuel tank if you can. I just put a external VL pump on mine with a serge tank. Apart from that its a easy swap. You should have a look at my website at the pics ect of mine. http://www.zook4x4.oz20.com If you need any other advise PM me or mail me and I'll give you my phone number. |
| Author: | ookie [ Fri Aug 03, 2007 5:58 pm ] |
sp1086 wrote: Yes been there done that...
NOW LISTEN UP!!! If your going to do this yourself / backyard it. I cant stress this enough so here it is in CAPS.. Try to see it all in the vehicle b4 you but it. Yeah get a efi fuel tank if you can. I just put a external VL pump on mine with a serge tank. Apart from that its a easy swap. You should have a look at my website at the pics ect of mine. http://www.zook4x4.oz20.com If you need any other advise PM me or mail me and I'll give you my phone number. Thanks for putting my mind at rest before i started pulling my car apart and yes the motor and all its components are from the same vehicle as i brought a rolled lwb with everything still intact. regards Emma |
| Author: | sp1086 [ Fri Aug 03, 2007 8:58 pm ] |
Thats good Emma. If you need any help just ask.. |
| Author: | mrw82 [ Sat Aug 04, 2007 3:01 am ] |
the G16a your pulling out, what condition is it in? and is it for $ale??? |
| Author: | offroader-rama [ Mon Aug 06, 2007 11:51 am ] |
i have a reco'd g16 8 valve head never being on car sence being done for sale if it had head gaskets problems etc... |
| Author: | ookie [ Thu Aug 09, 2007 12:27 am ] |
sorry already have a friend wanting the motor for his sierra but if that changes i'll let you know |
