It is currently Sat Nov 14, 2026 4:53 pm
Post Posted: Mon Jan 08, 2007 12:42 am
i have a 91 sierra.
ive just take out the rear axles. the bearings have 0.5 to 1mm play in them
do i need special tools to remove and replace..
im thinking i need some sort of press or something.
or is it easier to take to mechanic to remove and replace.
Vehicle: 75 Cruiser
Post Posted: Mon Jan 08, 2007 12:44 am
i haven't done one for a while but from memory, we bashed the crap out of it to get it off and used a press to get the new one on.
Post Posted: Mon Jan 08, 2007 2:20 am
ive always had access to a press and the proper tools and never used em :wink:
to remove, sit bearing on something solid, wrap tightly in rags, put glasses on and smash with hammer :twisted:
then the 2 inner bits you have left, cut a groove a few mm thick with an angle grinder, then bash crap out of said groove with hammer and cold chisel, this will spread it and crack the races so they will slide off
to put one on I just use a bit of 32NB thick wall pipe and bash em on, prob not the best way but its easy and the bearing never twists or gets stuck
Post Posted: Mon Jan 08, 2007 11:58 pm
ok thanks for that.
aka
aka
Post Posted: Fri Nov 09, 2007 5:24 pm
Hey guys,
Excuse my ignorance but what is 32NB Wall Pipe? I am assuming it is the size of a piece of p[ipe.
If I go the the metal joint down the road will they know what I am after?
Rapson
Experience is something you dont get until just af
Post Posted: Fri Nov 09, 2007 5:29 pm
yeah 32nb is 32mm nominal bore, basically 1 1/4 water pipe
will be about 42mm OD and 5mm wall thickness, check thats the right size to slip over the axle 1st though cause I could have the wrong size
aka
aka
Post Posted: Fri Nov 09, 2007 5:37 pm
Beauty, thanks Royce,
I think when I take the axel out I will take it to the metal shop and get the right size pipe.
So the pipe should be pretty snug around the axel so as to bash the inner race of the bearing down.
Post Posted: Fri Nov 09, 2007 5:46 pm
yeah you want it to hit the inner race and not the seal section of bearing, the pipe will either be a pretty good fit or way to big, there arent too many different sizes when it comes to pipe
Post Posted: Mon Nov 12, 2007 11:31 pm
Ahh good work Royce... At what year Motor Mechanics Apprentices do you learn that procedure, or was that in Bush Mechanics School.
That is why they call on Royce when things go BANG in the bush Oh and Caboolture :lol: :lol: :lol:
Steve W
Post Posted: Tue Nov 13, 2007 12:33 am
this is what you learn when you have a job to do and bugger all of the correct tools to do it with
Post Posted: Tue Nov 13, 2007 3:13 am
Yep know what ya talkin about there i have a shed full of the wrong tools but I do have a welder grinder and some big hammers that tend to do the job :lol:
Steve W
Users browsing this forum: Google [Bot], seanzook06 and 77 guests
