The zook all of a sudden doesn't idle. It dies when I stop. Sparks have been done no less than 1 month ago. Getting quite sick of it. What could it be? I just serviced it yesterday (Oil change and Filter).
Joined: Mon Oct 27, 2008 10:30 pm Posts: 1027 Location: north brisbane
Vehicle: lj81 stockman
Posted: Mon Jun 07, 2010 2:50 am
idle solenoid is blocked rite side of the carby 2 wires going in to it,take it out and clean it and blow air up the hole too. Make shore it clicks when u turn the key on
Joined: Tue Jul 28, 2009 11:30 pm Posts: 455 Location: Newcastle NSW
Vehicle: I drive your mum
Posted: Tue Jun 08, 2010 12:32 am
The idle jet in the standard carb is stupidly small and easily gets clogged. Clean the carb out and blow through the jets. Then fit a second fuel filter between the fule pump outlet and the carb inlet. Often the diaphram of an old pump starts to fall apart letting bits of rubber into the fuel lines.
Users browsing this forum: No registered users and 218 guests
