| wiring help newcastle area http://auszookers.com/forum/viewtopic.php?f=5&t=12545 |
| Author: | simozuk [ Mon Jun 07, 2010 5:48 am ] |
| Post subject: | wiring help newcastle area |
hey guys have just installed the mk3 suzuki swift gti twin cam engine into a sierra which i am running the lt8 after market computer and hand controller! my mate has wired up all the ecu! and everything else like starter alternator earth wire's etc and its still not cumming up with any dash lights and not starting there is nothing at all! if any of u guys know of a good work shop to take it to in newcastle area i would be greatful thanks simon |
| Author: | weaves [ Mon Jun 07, 2010 6:29 am ] |
| Post subject: | Re: wiring help newcastle area |
I guess something like that Black track (the old RX engineering) might be the go around here. Ask Mcwilly who tuned his microtech (if it wasnt already in the car when he bought it) weaves |
| Author: | LAY80N [ Tue Jun 08, 2010 12:24 am ] |
What acutally happens, does the car crank. What dash lights are you missing. The alternator and brake warning lights should still work as the wiring for them is independant of the engine. The starter circut should cause the motor to turn over regardless if its carby or injection as it is also independant of the engine managment system. If it doesnt crank at all you have issues in the power supply to the car or the cranking system. Have you grabbed a test light and multimetre and checked everything. Does the ECU turn on when you turn the key to on? Have you checked that you are getting ignition signal from the key at the ECU. I can offer a bit of a hand if your stuck. Basically make sure the base wiring in the car is good first, then grab a wiring diagram and go over all your wiring. Layto.... |
