It is currently Mon Oct 12, 2026 2:49 am
Post Posted: Tue Jun 08, 2010 8:37 am
hey guys im just after some winch info?
so if anyone can help it would be awsome thanks,
ok what it is would a 5000lbs winch pull a zook easy or would i be better bumping it up and getting sometihng bigger thanks
any help would be awsome thanks guys
Post Posted: Tue Jun 08, 2010 8:39 am
i have a 6500 and it works well
Post Posted: Tue Jun 08, 2010 8:46 am
all the info i have is
5000lb warn winch with hook and fairlead
and its $200 should i get it??
Post Posted: Tue Jun 08, 2010 8:53 am
if it works and is in good nik thats good buying mate.could be good enough for ya zook
Post Posted: Tue Jun 08, 2010 8:56 am
10000lb with a snatch block :wink:
Vehicle: SJ80
Post Posted: Tue Jun 08, 2010 9:02 am
I have a 6000lb Warn winch on my Sierra. I reckon it would pull the front bar of the car before the winch stalled. :twisted:
If the winch is functional and you have a need for it, then it sounds like a good buy. You can buy parts for Warn winches too, so that's a plus.
Vehicle: jimny
Post Posted: Tue Jun 08, 2010 9:38 am
For that price grab it
Vehicle: MY2019 Jimny
Post Posted: Tue Jun 08, 2010 10:03 am
Don't get it.
Give me the bloke's number and I'll sort him out for trying to rip you off...
Post Posted: Tue Jun 08, 2010 10:36 am
sadly no it won't....a 6000 is rubbish.......but better than nothing.
if its a 'permanent magnet' motor steer clear of it. if its a 'series wound' than it might be a good thing.
Post Posted: Tue Jun 08, 2010 10:50 am
have a look @ the tigerz11 winches they are supposed to be prety good. i want 1 but cant afford it :(
Post Posted: Tue Jun 08, 2010 10:52 am
buy a second hand warn 8000 or 9000. they are everywhere and cheap.
Vehicle: SJ80
Post Posted: Wed Jun 09, 2010 12:09 am
Why is that Joe? Do the M6000s have inferior gearing, shorter service life or something else wrong with them? :( :?
It's still a series wound winch, and while it's smaller, it recovers the Sierra comparably to what the M8000 in my wife's fourby can self recover. 8)
Post Posted: Wed Jun 09, 2010 7:09 am
6000lbs have superior gearing, but if you're into bogging the car really hard you may need to use a snatch block.
The 6000lb Warn winch has a very high low load line speed, so they are excellent at "assist winching" - where you can nearly drive but can't quite get enough traction. This seems to be a lot of the winching I've seen.
I guess it depends on what you expect from a winch and what kind of driving you do. Personally, I'd rather a faster winch and use a snatch block occasionally to a really, really slow winch with a higher load rating.
I know nothing of the 5000lb Warn - my experience is with 6K's and I'd run one without an issue.
Users browsing this forum: No registered users and 224 guests
