| Spot light for a reverse light http://auszookers.com/forum/viewtopic.php?f=5&t=13046 |
| Author: | Joe [ Fri Jun 25, 2010 8:47 am ] |
| Post subject: | Spot light for a reverse light |
Gday guys i wana use a small spot light i have here for a reverse light. To hook it up is it as simple as joining the wires from the stock reverse lights to the spot light or is there a bit more to it Cheers Joe |
| Author: | royce [ Fri Jun 25, 2010 8:52 am ] |
| Post subject: | Re: Spot light for a reverse light |
nah they might not take the load, better off to run a relay and get power from the battery |
| Author: | ajsr [ Fri Jun 25, 2010 8:54 am ] |
get on fleabay and find a led spotlight , no load issues then |
| Author: | Joe [ Fri Jun 25, 2010 8:56 am ] |
LED sounds good and easy |
| Author: | Jester [ Fri Jun 25, 2010 9:01 am ] |
Ive used the relay method and have twin 55w spotties on the rear bar, just need to fix the switch on the gearbox! |
| Author: | Joe [ Fri Jun 25, 2010 9:07 am ] |
Yeah but im not that smart when it comes to relays and stuff So if i go for an LED light can i just join the wires or do i still have to piss fart about with relays and stuff |
| Author: | christover1 [ Fri Jun 25, 2010 9:23 am ] |
I'm running a single 55w small round light straight off the reverse wire behind the indicator assembly..would not risk 2, as too much for cicuit..but never had and probs woth using 1 low watt H3 on any car |
| Author: | christover1 [ Fri Jun 25, 2010 9:24 am ] |
Jester wrote: Ive used the relay method and have twin 55w spotties on the rear bar, just need to fix the switch on the gearbox!
I gave up and put a manual switch on mine |
| Author: | ainzy [ Fri Jun 25, 2010 10:31 am ] |
i ran two small spots on my patrol straight off the reverse wire never had a worry but that was a patrol now i own a zook im not so sure this thread intrests me as im building a tray for my shorty at moment ill be using LED fot the zook though they are the future |
| Author: | hutch [ Fri Jun 25, 2010 11:11 am ] |
joseph wrote: Gday guys i wana use a small spot light i have here for a reverse light.
To hook it up is it as simple as joining the wires from the stock reverse lights to the spot light or is there a bit more to it Cheers Joe If its an LED straight off reverse wire should be fine, but if not as royce says. |
| Author: | royce [ Fri Jun 25, 2010 11:15 am ] |
relay is pretty easy screw the relay in the back somewhere near a tail light run a decent wire from battery positive to pin 30 on the relay, put a 30 amp fuse near the battery run a decent wire from pin 87 to the spotty, earth the spotty if it needs it run a skinny wire or thicker earth pin 85 enjoy the sparkling goodness you can get fancy with switches to turn it off all the time or on when you want as well as reverse but we'll worry about that later |
| Author: | imatt [ Fri Jun 25, 2010 11:29 am ] |
Go the relay option, its not hard to wire up and if you put a switch on the dash you can turn it off, especially useful when in shopping centre carparks, spotlights used for reversing lights are bloody bright. Cheers Matt |
| Author: | Jester [ Fri Jun 25, 2010 11:32 am ] |
yeah ive got the switch on the dash too |
| Author: | Joe [ Fri Jun 25, 2010 1:45 pm ] |
royce wrote: relay is pretty easy
screw the relay in the back somewhere near a tail light run a decent wire from battery positive to pin 30 on the relay, put a 30 amp fuse near the battery run a decent wire from pin 87 to the spotty, earth the spotty if it needs it run a skinny wire or thicker earth pin 85 enjoy the sparkling goodness you can get fancy with switches to turn it off all the time or on when you want as well as reverse but we'll worry about that later Haha nope ya lost me I think ill just get a auto sparky to do it for me Is it possible to have it as a reverse light but have a switch so i can just flick it on when out camping to have light for say cooking and stuff??? |
| Author: | Joe [ Fri Jun 25, 2010 1:46 pm ] |
Not that i do any cooking cause thats Kate's job |
| Author: | MacDaddy [ Fri Jun 25, 2010 2:33 pm ] |
hutch wrote: joseph wrote: Gday guys i wana use a small spot light i have here for a reverse light. To hook it up is it as simple as joining the wires from the stock reverse lights to the spot light or is there a bit more to it Cheers Joe If its an LED straight off reverse wire should be fine, but if not as royce says. I have been looking at the LED Spots/Worklights on eBay too, they put out a real bright White light, 4WD stores are selling them now... you could run a couple of them off the reverse wire no problem, those LED Lights would not even draw 1amp ! Here's a thought Joseph, why not put that spot light on your roll bar, and make it movable/directional, so you can point it where you want it... maybe... just a thought... he he... |
| Author: | steve [ Fri Jun 25, 2010 8:28 pm ] |
joseph wrote: Is it possible to have it as a reverse light but have a switch so i can just flick it on when out camping to have light for say cooking and stuff???
i think you'd run the risk of a flat battery if you left a spot/flood light on while at camp. I have a flouro light that i can leave on all night and doesn't drain the battery, or the led light option might work for that aswell. But for a proper reverse light a proper spot or flood light would be better than leds. |
| Author: | Gwagensteve [ Fri Jun 25, 2010 10:08 pm ] |
joseph wrote: royce wrote: relay is pretty easy screw the relay in the back somewhere near a tail light run a decent wire from battery positive to pin 30 on the relay, put a 30 amp fuse near the battery run a decent wire from pin 87 to the spotty, earth the spotty if it needs it run a skinny wire or thicker earth pin 85 enjoy the sparkling goodness you can get fancy with switches to turn it off all the time or on when you want as well as reverse but we'll worry about that later Haha nope ya lost me I think ill just get a auto sparky to do it for me Is it possible to have it as a reverse light but have a switch so i can just flick it on when out camping to have light for say cooking and stuff??? Seriously Joseph, buy a relay, turn it upside down so you can look at the little diagram of the terminals, and read Royces post again. wiring a relay isn't hard. Really, It's not. Royce's instructions are spot on, but it's hard to see what you have to do unless you are looking at the relay. There are good reasons to run an LED light, but there are even better reasons to be able to wire a relay. Running a 55w light off the stock loom might be OK, but I don't think it's a great idea. As for switching it from either the reverse light or an external switch, it's quite possible. I've never really bothered though - just leave the car with the ignition on and in reverse. I have a 55w flood light as my camping/reverse light but it's on a separate switch - I don't want it coming on all the time, even at night or in the bush necessarily - when I reverse. Steve. |
| Author: | alex [ Fri Jun 25, 2010 10:14 pm ] |
| Author: | Ben_Sierra [ Fri Jun 25, 2010 11:44 pm ] |
joseph wrote: royce wrote: relay is pretty easy screw the relay in the back somewhere near a tail light run a decent wire from battery positive to pin 30 on the relay, put a 30 amp fuse near the battery run a decent wire from pin 87 to the spotty, earth the spotty if it needs it run a skinny wire or thicker earth pin 85 enjoy the sparkling goodness you can get fancy with switches to turn it off all the time or on when you want as well as reverse but we'll worry about that later Haha nope ya lost me I think ill just get a auto sparky to do it for me Is it possible to have it as a reverse light but have a switch so i can just flick it on when out camping to have light for say cooking and stuff??? Bring it to my place I'll do it for a 6 pack |
| Author: | Joe [ Sat Jun 26, 2010 12:19 am ] |
Ben_Sierra wrote: joseph wrote: royce wrote: relay is pretty easy screw the relay in the back somewhere near a tail light run a decent wire from battery positive to pin 30 on the relay, put a 30 amp fuse near the battery run a decent wire from pin 87 to the spotty, earth the spotty if it needs it run a skinny wire or thicker earth pin 85 enjoy the sparkling goodness you can get fancy with switches to turn it off all the time or on when you want as well as reverse but we'll worry about that later Haha nope ya lost me I think ill just get a auto sparky to do it for me Is it possible to have it as a reverse light but have a switch so i can just flick it on when out camping to have light for say cooking and stuff??? Bring it to my place I'll do it for a 6 pack Ill send ya a pm when i go on my next break |
| Author: | BlueSuzy [ Sat Jun 26, 2010 1:41 am ] |
I used a relay on my driving light/reverse lights now, as i blew the reverse switch in the gearbox when i didnt run a relay... |
| Author: | whincup [ Sat Jun 26, 2010 8:14 am ] |
christover1 wrote: I gave up and put a manual switch on mine
this would be great for the idiots tailgating... soon as theyre too close, let it rip! |
| Author: | appsie [ Sat Jun 26, 2010 8:18 am ] |
a mate of mine had 2 x 100w night visions on his tailgate of his zuk pointing back.thought it would be funny to flash some people in the face at the lights one night.Was funny till the cops put their lights on |
| Author: | Ben_Sierra [ Sat Jun 26, 2010 9:22 am ] |
So you want those lights hooked up Joe? |
| Author: | shandy92 [ Sat Jun 26, 2010 9:26 am ] |
appsie wrote: a mate of mine had 2 x 100w night visions on his tailgate of his zuk pointing back.thought it would be funny to flash some people in the face at the lights one night.Was funny till the cops put their lights on
ahaha busted, i would prob do that lol |
| Author: | Joe [ Sat Jun 26, 2010 5:21 pm ] |
Ben_Sierra wrote: So you want those lights hooked up Joe?
| Author: | MacDaddy [ Sat Jun 26, 2010 6:48 pm ] |
Hey lets all rock up to Joe's place and help him connect the lights up ! |
