It is currently Fri Oct 16, 2026 7:13 am
Post Posted: Thu Aug 19, 2010 9:39 pm
Hi All,
Going away this weekend and want to get a bit more storage area out of the Jimny, is anyone able to advise how to remove the rear seats?
So far I have managed to un-clip and take out the bench part you sit on, so all that is left is the backrest which seems bolted to the side accessory trays.
Any ideas how to remove the backrest?
It is a 2010 Model
Post Posted: Thu Aug 19, 2010 10:41 pm
in the bottom corner of the seat near the bolt is a velcro flap. lift that and there will be a bolt, take that out and the the seat will come out. then u just undo the nut that holds the bracket on. took me a while to figure it out but when u know what your doing its easy as.
Post Posted: Thu Aug 19, 2010 10:45 pm
Doing that, you still end up with pins coming out of the plastic 1/4 panel. You can remove them by removing the plastic 1/4 panel. (big job)
Post Posted: Fri Aug 20, 2010 12:39 am
you will have to grind them off so when its done your cant put the seats back in.
Vehicle: Jimny, Lifted on 30's
Post Posted: Fri Aug 20, 2010 7:19 am
http://auszookers.com/index.php?name=Fo ... ic&t=13651
did i the other week theres some pics and info :D
Nick.
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Fri Aug 20, 2010 2:00 pm
the bolts sticking out have to be cut off.
i did it to mine but i will never want back seats again (well i hope so)
and taking the panels off isn't hard =]
Post Posted: Fri Aug 20, 2010 2:01 pm
too bad if the next owner wants rear seats :lol: 8O
Vehicle: Currently vehicle-less
Post Posted: Fri Aug 20, 2010 11:32 pm
the bolts dont have to be cut or removed in any way.
Users browsing this forum: Google [Bot], JoshuaM95 and 211 guests
