| Quick Diff question http://auszookers.com/forum/viewtopic.php?f=5&t=13533 |
| Author: | Mick70b [ Wed Jul 14, 2010 3:02 am ] |
| Post subject: | Quick Diff question |
I'm just about to fork out $450 for a complete steel GV front diff. Just checking that a '99 GV Steel diff will fit my '97 Vit, Both are 26 spline and I've got the 5.12 R&P ready to go, so I just have to have the 5.12s swapped into the new GV diff ... is that right ??? |
| Author: | atari4x4 [ Wed Jul 14, 2010 3:06 am ] |
| Post subject: | Re: Quick Diff question |
yep |
| Author: | atari4x4 [ Wed Jul 14, 2010 3:08 am ] |
there are 2 types of pinion mounts.... being a 99 it will be the early type that are the same as the SV's late model
early model
| Author: | BlueSuzy [ Wed Jul 14, 2010 3:10 am ] |
that looks yuck. |
| Author: | Mick70b [ Wed Jul 14, 2010 3:15 am ] |
Good stuff thanks guys ... yeah that does look yuk (ouch)! |
| Author: | atari4x4 [ Wed Jul 14, 2010 3:15 am ] |
BlueSuzy wrote: that looks yuck.
pure alloy goodness.... |
| Author: | Mick70b [ Wed Jul 14, 2010 3:17 am ] |
You really have to wonder 'what the f#@k' were Suzuki thinking? |
| Author: | BlueSuzy [ Wed Jul 14, 2010 3:22 am ] |
Mick70b wrote: You really have to wonder 'what the f#@k' were Suzuki thinking?
with coilys and jimnys also.. |
| Author: | Joe [ Wed Jul 14, 2010 6:23 am ] |
atari4x4 wrote: there are 2 types of pinion mounts.... being a 99 it will be the early type that are the same as the SV's
![]() It was late 98 suzuki changed the pinion mounts You can fit the later model diffs but ya have to bash the sump in to make room for the pinion mount Gus can ya post up the link that ya sent me with the pics of belted in sump |
| Author: | atari4x4 [ Wed Jul 14, 2010 9:46 am ] |
really... i thought it was after 99.... SORRY http://auszookers.com/index.php?name=Fo ... 639#128639 |
| Author: | Joe [ Wed Jul 14, 2010 9:53 am ] |
Yeah the one i was gunna buy off Redzook was from a late 98 model and had the different mount and Stueys is from an early 98 model |
| Author: | redzook91 [ Wed Jul 14, 2010 10:01 am ] |
joseph wrote: Yeah the one i was gunna buy off Redzook was from a late 98 model and had the different mount and Stueys is from an early 98 model
Ended up keeping it and gonna do some sump bashing waste not, want not... |
| Author: | Joe [ Wed Jul 14, 2010 10:04 am ] |
redzook91 wrote: joseph wrote: Yeah the one i was gunna buy off Redzook was from a late 98 model and had the different mount and Stueys is from an early 98 model Ended up keeping it and gonna do some sump bashing waste not, want not... Wasn't Royce gunna get it off ya????? Should of sold it to that fella from the NT,didn't he offer ya $600 for it |
| Author: | Mick70b [ Wed Jul 14, 2010 10:13 am ] |
I've paid my deposit now so I guess I will see when I pick it up next week (after pay day) |
| Author: | redzook91 [ Wed Jul 14, 2010 11:24 am ] |
joseph wrote: redzook91 wrote: joseph wrote: Yeah the one i was gunna buy off Redzook was from a late 98 model and had the different mount and Stueys is from an early 98 model Ended up keeping it and gonna do some sump bashing waste not, want not... Wasn't Royce gunna get it off ya????? Should of sold it to that fella from the NT,didn't he offer ya $600 for it Yes that was a confusing episode, lots of um-ing and ah-ing ad non-replied PM's so i thought bugger it, i'll just keep it (probably won't find another for 250 again so perhaps for the best). it's still out of the car awaiting a tax cheque to install a locker before it goes in armsup . Back on topic, hope it all works for ya mick |
| Author: | Mick70b [ Wed Jul 14, 2010 11:41 am ] |
Thanks mate, will let you know how it goes I take it the pinion mounts can't be changed either ... Do all the mounting holes etc, still line up with the original ones ? |
| Author: | DarkHorse [ Wed Jul 14, 2010 3:07 pm ] |
Ooooh, tax time... there's a tempting idea I didn't need... |
| Author: | atari4x4 [ Wed Jul 14, 2010 3:12 pm ] |
Mick70b wrote: Thanks mate, will let you know how it goes
I take it the pinion mounts can't be changed either ... Do all the mounting holes etc, still line up with the original ones ? the mounts on the outside are the same, the pinion mount is different where it bolts to the pinion carrier but where they pinion mount bolts to the crossmember is the same.... grab all of the pinion mount off the GV. |
| Author: | Mick70b [ Thu Jul 15, 2010 7:19 am ] |
Thanks Atari I will do, I will see what it looks like when I get it. I may even grab another sump and cut n shut the corner off it and get it ready prior to fitting the diff it is looks like it's going to foul. |
| Author: | got_bar_work [ Thu Jul 15, 2010 7:25 am ] |
mine did the sump mod on its own i had to re drill the holes ine the mounts because of the amount of drop my diff has i made it ge as far forward as i could |
| Author: | Mick70b [ Tue Jul 27, 2010 5:15 am ] |
Just picked up my GV Steelie and that f#@k it's got the same pinion mount as the one I've got in it now, so all should be good |
| Author: | inbits [ Thu Dec 30, 2010 9:56 am ] |
Grave dig will the later model pinion mount foul on the sv620 v6 sump |
| Author: | atari4x4 [ Thu Dec 30, 2010 10:03 am ] |
i "think" tombutt is running the later pinion mount |
| Author: | inbits [ Thu Dec 30, 2010 10:13 am ] |
Ok I'll check his build up thanks |
| Author: | gregdixon [ Fri Dec 31, 2010 5:53 am ] |
My Gv is a 99 and has the same pinion mount as the sv, as atari said. The alloy diffs are fine at doing what they were designed for. Suzuki didn't plan on fitting 31's, 5.12's and lockers when they designed them |
| Author: | inbits [ Fri Dec 31, 2010 6:00 am ] |
I broke mine on stock highway terrains I have confirmed with tombutt that the later gv mounts clear the h20 sump easily so that makes it easier for people with the sv620 models |
