It is currently Mon Oct 05, 2026 3:10 pm
Post Posted: Tue Jul 13, 2010 10:46 am
Hey,
Starting my coilpack 1.6 conversion this w/end. Just wondering what ppl have done about the knock sensor when fitting the 1.3 sump? Mounted it elsewhere, modified the sump or bought a aftermarket sensor and mounted on the block somewhere?
Also what brand extractors fit a 93 WT with the bent kit used to fit a coilpack 1.6?
Thanks
Post Posted: Tue Jul 13, 2010 10:49 am
the thing at the front? thats the crank angle sensor
you either need to weld the section of baleno sump in or get the dump off a late vit / x90 with teh mount for it, joeblow has made mention of that on here before somewhere
Post Posted: Tue Jul 13, 2010 10:51 am
X2.
No knock sensors on a baleno.
As royce said, either cut and shut the baleno sump with a sierra one, or get an X-90 sump.
Post Posted: Tue Jul 13, 2010 11:08 am
ahah, ok anybody ever cut/shut baleno-sierra one before? pics?
?? What is this? sump yer?
Post Posted: Tue Jul 13, 2010 11:10 am
yeah could be, not well known for looking when I type :wink:
Post Posted: Tue Jul 13, 2010 11:32 am
Moded sierra sump.
Post Posted: Tue Jul 13, 2010 12:48 pm
Did you just go out & take that then Mr fat??
:P Good on ya!!! :P :P
Post Posted: Tue Jul 13, 2010 12:58 pm
Yep, thanks mate. will have a go at it on friday night.
Post Posted: Tue Jul 13, 2010 1:42 pm
Yep 8)
Post Posted: Wed Jul 14, 2010 8:26 am
Is this basically where your cut was?
Post Posted: Wed Jul 14, 2010 8:29 am
yeah. Just be careful to line the flange up. Otherwise you may get a leak.
Post Posted: Thu Jul 15, 2010 8:45 am
Hey fatzook,
anymore pics, im looking at both my sumps and i cant make out what you did at the curve bit of the baleno sump if you no what i mean?
Also what extractors for the baleno motor
cheers
Post Posted: Thu Jul 15, 2010 11:30 am
birko wrote:
Hey fatzook,
cheers
I'll get some during the day tomorrow. I had to 'shape' the sump a little to get the 2 pieces to line up, as they are a slightly different profile from memory.
As for extractors, just use 16v EFI vitara extractors. They are essentially the same head.
Peter
PS. I need your phone number for frieght carrier 8) PM me
Users browsing this forum: No registered users and 193 guests
