| Power steering upgrade on G13a http://auszookers.com/forum/viewtopic.php?f=5&t=13995 |
| Author: | vandle [ Sun Aug 01, 2010 12:57 pm ] |
| Post subject: | Power steering upgrade on G13a |
Have installed a jimny box and steering pump onto a sierra with a G13a. jimnys run groove belts and G13a run v belts. are there any accessory groove belt pullys available that are able to be bolted to the v belt pully on the crankshaft? any suggestions would be grateful. |
| Author: | lukes_89 [ Sun Aug 01, 2010 4:00 pm ] |
| Post subject: | Re: Power steering upgrade on G13a |
i think the way to do it is the change from v belts to the multi rib belts that way you can also run a falcon alternator as well |
| Author: | steak_knife [ Sun Aug 01, 2010 8:26 pm ] |
Swift with G13 eng in it. |
| Author: | jdk81 [ Sun Aug 01, 2010 10:15 pm ] |
If you are lucky yoy may find a pulley with single V for alt and waterpump, and a multi V for A/C/PS. The sierra water pump cant fit the multigroove pulley, so you need to convert to a barina or baleno water pump. These cant support the rad fan, so thermo fan is required. And do a falcon alt while you are it, while posted above. You may find a vit water pump with multigroove, then you can fit the clutch fan and vit fan shroud to the radiator. If I am misinformed in any way, please let me know. As I haven't done this conversion as yet. But will be doing it to a G16B engine, that I will install soonish. I have a cressida P/S box, 110A falcon Alt, need to go get a teardrop style P/S pump, and thermo fans. |
| Author: | BlueSuzy [ Mon Aug 02, 2010 12:55 am ] |
Just change the pulleys from the swift g13b multiv's. They easily bolt off. The Baleno water pumps do support the engine fan, just use the sierra bolts and spacer. |
| Author: | vandle [ Tue Aug 03, 2010 5:57 am ] |
Thanks everyone for your help, I now have something to go on. |
| Author: | BenT [ Tue Aug 03, 2010 10:48 am ] |
jdk81 wrote: The sierra water pump cant fit the multigroove pulley
The water pump pulley from an 8 valve Vitara will fit the Sierra water pump. You can fit a Vitara crank pulley once you re-drill the bolt pattern from 5 holes to 4 holes. For the alternator, just use a Vitara one, then you get a power upgrade as well. Ben |
