It is currently Thu Oct 01, 2026 1:05 am
Post Posted: Mon Aug 02, 2010 5:20 am
i had a whinge coming from what i thought was the rear diff, i changed diffs and the whinge is still there.
What could be causing this noise? it only really starts when i hit about 80kms and stop s when i back off.
Post Posted: Mon Aug 02, 2010 5:29 am
could be wheel bearing
Post Posted: Mon Aug 02, 2010 5:48 am
what did the rear bearings look like when you removed the axles?
ball bearings often make a whine when they are on there way out.
Vehicle: LJ20 LJ50
Post Posted: Mon Aug 02, 2010 5:59 am
punch your wife...... that should stop the whingeing
Camels have nice toes
Post Posted: Mon Aug 02, 2010 6:01 am
Or increase it 10 fold lol
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Mon Aug 02, 2010 8:13 pm
The noise may not be the diff. Have you had the car on a hoist (or stands) to hear the noise from the source. Quite often noises from the transfer/gearbox can sound like they're coming from the back.
When mine did that it turned out to be the hard casing on the pinion shaft.
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Post Posted: Mon Aug 02, 2010 11:38 pm
yeah wheels bearings where my next guess but they didn't look to bad when i pulled axels out,
Post Posted: Tue Aug 03, 2010 12:06 am
Mine was vibrating whining like a bitch.
Turned out to be the rear uni on ther tailshaft. She was seized..
Post Posted: Tue Aug 03, 2010 2:36 am
so best bet would be to take it to a mechanic then i suppose
Post Posted: Tue Aug 03, 2010 2:41 am
if your not able to do bearings your self, yes
Post Posted: Fri Aug 06, 2010 10:35 am
the transfer case looks like its been leaking oil might that be part of the problem? should i check fluid?
Post Posted: Fri Aug 06, 2010 11:10 am
8O Um, yes... 8O
That mud hole you ploughed through will eat out seal's in EVERYTHING, checking oil level's should be part of your wash down..
Post Posted: Fri Aug 06, 2010 11:26 am
oh you saw that didn't you??? it was quite big wasn't it i thought i was going to need a snatch, i don't have a socket or spanner big enough for the transfer case. otherwise i would of.
Users browsing this forum: Google [Bot] and 184 guests
