http://auszookers.com/forum/
Driveshaft spline
http://auszookers.com/forum/viewtopic.php?f=5&t=14115
Author:  Moph [ Fri Aug 06, 2010 6:36 am ]
Post subject:  Driveshaft spline
Am pulling my transfer tomorrow to fit a Roctoy ring and 2" JC transfer lift ... with the length of spline I have showing there, can anyone give me an idea what thickness (if any) driveshaft spacer I need?
About time I put the 2" mounts in ... though vice grips work impressively well!
Author:  finlay113 [ Fri Aug 06, 2010 6:43 am ]
Post subject:  Re: Driveshaft spline
I've got a 10 mm snake racing spacer if that's what you end up needing. Let me know
Author:  Red89 [ Fri Aug 06, 2010 8:29 am ]
Looks fine as is to me.
Author:  BlueSuzy [ Fri Aug 06, 2010 8:51 am ]
i run a 30mm spacer. Ruf, Dif is 25/30mm forward. 2'trans lift, but 1'or less lift in springs, spua.
Author:  Moph [ Fri Aug 06, 2010 9:01 am ]
Cool - that's about what mine is - RUF, front 1"ish forward, rear 0.5"ish back, 1"ish spring lift, soon-to-be 2" transfer lift. Will put the lift in then have a look at it again.
Author:  BlueSuzy [ Fri Aug 06, 2010 2:25 pm ]
my rear diff is only about 15mm rearward, so no spacer needed, and had no spline drama's other than the boot tearing on the chassis.. :lol:
I now fixed that by turning the shaft upside down, so now the tailshaft hits the chassis.. :lol:
Author:  daisy [ Fri Aug 06, 2010 7:18 pm ]
two of our zooks run them exactly like that with no spacers. seem to be fine.
