http://auszookers.com/forum/
what started do I need?
http://auszookers.com/forum/viewtopic.php?f=5&t=14117
Author:  hutch [ Fri Aug 06, 2010 7:18 am ]
Post subject:  what started do I need?
Ok just in case I need to source a starter motor.
I have a g1.6b vit block Carby and a 1.3 sierra head with 1.3 gearbox with adapter plate.
Do I need the 1.3 sierra starter or a 1.6 vit starter?
Does the adapter plate make anydifferece to the mounting of the starter?
Author:  finlay113 [ Fri Aug 06, 2010 7:20 am ]
Post subject:  Re: what started do I need?
Pretty sure ya need a 1.6 one. But you can use a 1.3 one if you grind a bit off it to make it fit. However I don't know which bit you have to grind off lol
Author:  Bruce [ Fri Aug 06, 2010 7:35 am ]
Hutch I have a 1.3 starter that you can have mate. And I'm sure you are right finlay, ya just need to grind a little off to make it fit.
Author:  steak_knife [ Fri Aug 06, 2010 7:52 am ]
1.6 reduction starter fit's a treat.. :P
Author:  hutch [ Fri Aug 06, 2010 7:56 am ]
Thanks Bruce, but I will most likely buy a new one when I need it.
Author:  hutch [ Fri Aug 06, 2010 7:57 am ]
cool
Author:  BlueSuzy [ Fri Aug 06, 2010 8:47 am ]
Some people grind the block...scary!
I machined down my startermotor. The main body outer on the lathe, and linished the mount and top cover to suit. Works fine. But i have access to machinery 4 free..
