It is currently Wed Sep 30, 2026 12:52 pm
Post Posted: Fri Aug 06, 2010 2:48 pm
the rule stops at 36" and the tyres are 28" would 31s fill the gap ???
or should i drop it a bit
Post Posted: Fri Aug 06, 2010 3:00 pm
31's will not fill the gap.. 1.5 inches bigger will do fark all.
What is your setup?
From what i can see,
Piss off those shackles with that 2-3" sus lift. They will do you no good! Flex worse than stock. I have done it with mine. Made it a stiff wheel lifting POS.
and 3-4" BL! WHY!??
With those tyres, you could run NO lift. With some small trimming only.
Your probably running at least 8" of lift there. Excluding tyre size/lift.
Your asking for BIG trouble!
Post Posted: Fri Aug 06, 2010 3:07 pm
3" and it was on the tub when i got it so ithought id use them they are threaded so they srew on to the studs in the tub and a prick to get off getting rid of the shackles would be a start though cheers
Post Posted: Fri Aug 06, 2010 3:10 pm
1: Get rid of BL
2: Get rid of Shackles
3: Keep Spring lift.
Post Posted: Fri Aug 06, 2010 3:23 pm
yeah i think i knew it was overboard but was after the easy way out, will have to go to work to get the oxy to try get them off with a bit of heat
Post Posted: Fri Aug 06, 2010 8:53 pm
1: Get rid of BL
No 1 & 2 X 2
Vehicle: MY2019 Jimny
Post Posted: Sat Aug 07, 2010 1:38 am
steknig wrote:
1: Get rid of BL
No 1 & 2 X 2
X more.
Post Posted: Sat Aug 07, 2010 2:31 am
but two inch would be acceptable ??? i need two get it up a bit to try and stop my gas tank from grounding out last time i dropped on it it shattered the floor around the mounts. do these springs look bigger to you guys they have suz002 on them but i wasnt sure if they are raised or not ????
cheers for the advise gentlemen
Post Posted: Sat Aug 07, 2010 2:54 am
They look raised.
No height will stop you from hitting the tank. Thats what guards are for.
Post Posted: Sat Aug 07, 2010 2:56 am
They look raised.
:wink:
Post Posted: Sat Aug 07, 2010 6:58 am
hows that for free advertising :lol:
lose a heap of height mate,thats damn big.
and.........add one of these
Post Posted: Sat Aug 07, 2010 12:13 pm
already done dropped down to 1" , dont think my tank will fit in one of those, when i say gas tank i mean lpg
Post Posted: Sat Aug 07, 2010 12:35 pm
Give me the specs. I'll make one fit :wink:
Post Posted: Sat Aug 07, 2010 12:39 pm
cheers mate i'll measure it up tomorow
Users browsing this forum: Google [Bot] and 121 guests
