| is this asking for trouble http://auszookers.com/forum/viewtopic.php?f=5&t=14133 |
| Author: | benji [ Fri Aug 06, 2010 2:48 pm ] |
| Post subject: | is this asking for trouble |
the rule stops at 36" and the tyres are 28" would 31s fill the gap ??? or should i drop it a bit |
| Author: | BlueSuzy [ Fri Aug 06, 2010 3:00 pm ] |
| Post subject: | Re: is this asking for trouble |
31's will not fill the gap.. 1.5 inches bigger will do fark all. What is your setup? From what i can see, Piss off those shackles with that 2-3" sus lift. They will do you no good! Flex worse than stock. I have done it with mine. Made it a stiff wheel lifting POS. and 3-4" BL! WHY!?? With those tyres, you could run NO lift. With some small trimming only. Your probably running at least 8" of lift there. Excluding tyre size/lift. Your asking for BIG trouble! |
| Author: | benji [ Fri Aug 06, 2010 3:07 pm ] |
3" and it was on the tub when i got it so ithought id use them they are threaded so they srew on to the studs in the tub and a prick to get off getting rid of the shackles would be a start though cheers |
| Author: | BlueSuzy [ Fri Aug 06, 2010 3:10 pm ] |
1: Get rid of BL 2: Get rid of Shackles 3: Keep Spring lift. |
| Author: | benji [ Fri Aug 06, 2010 3:23 pm ] |
yeah i think i knew it was overboard but was after the easy way out, will have to go to work to get the oxy to try get them off with a bit of heat |
| Author: | steak_knife [ Fri Aug 06, 2010 8:53 pm ] |
BlueSuzy wrote: 1: Get rid of BL
2: Get rid of Shackles 3: Keep Spring lift. No 1 & 2 X 2 |
| Author: | lump_a_charcoal [ Sat Aug 07, 2010 1:38 am ] |
steknig wrote: BlueSuzy wrote: 1: Get rid of BL 2: Get rid of Shackles 3: Keep Spring lift. No 1 & 2 X 2 X more. |
| Author: | benji [ Sat Aug 07, 2010 2:31 am ] |
but two inch would be acceptable ??? i need two get it up a bit to try and stop my gas tank from grounding out last time i dropped on it it shattered the floor around the mounts. do these springs look bigger to you guys they have suz002 on them but i wasnt sure if they are raised or not ???? cheers for the advise gentlemen |
| Author: | BlueSuzy [ Sat Aug 07, 2010 2:54 am ] |
They look raised. No height will stop you from hitting the tank. Thats what guards are for. |
| Author: | Fatzook [ Sat Aug 07, 2010 2:56 am ] |
BlueSuzy wrote: They look raised.
| Author: | appsie [ Sat Aug 07, 2010 6:58 am ] |
hows that for free advertising lose a heap of height mate,thats damn big. and.........add one of these
| Author: | benji [ Sat Aug 07, 2010 12:13 pm ] |
already done dropped down to 1" , dont think my tank will fit in one of those, when i say gas tank i mean lpg |
| Author: | Fatzook [ Sat Aug 07, 2010 12:35 pm ] |
benji wrote: already done dropped down to 1" , dont think my tank will fit in one of those, when i say gas tank i mean lpg
Give me the specs. I'll make one fit |
| Author: | benji [ Sat Aug 07, 2010 12:39 pm ] |
cheers mate i'll measure it up tomorow |
