It is currently Sun Sep 20, 2026 11:54 pm
Post Posted: Mon Aug 09, 2010 6:41 am
I have recently aquired some Castrol multitrax manual transmission oil.
It is an API GL5, SAE80W-90 oil.
I have looked in the service manual and it says to use the same oil in
the diffs, gearbox and transfer (API GL5 80W-90).
However at the auto store (supercheap) in their book it says to use
different types of oils.
Is this just a marketing strategy or what?
Vehicle: 1987 sierra tray back buggy
Post Posted: Mon Aug 09, 2010 6:50 am
just use the same oil in all. supashit will prolly have a thicker oil listed for the diffs. But unless you have lsd diffs the lighter stuff will be fine.
Vehicle: LWB Sierra & XL7
Post Posted: Mon Aug 09, 2010 6:59 am
They usually have the castrol, valvoline or nulon books for referance.
'92 Vitara & Camper trailer
Post Posted: Mon Aug 09, 2010 7:45 am
That'll do it!!!
i like to run a straight 80w in the g/box, help's shifting, but not necessary..
Post Posted: Mon Aug 09, 2010 10:28 am
before using that oil in the diffs, check if it says its for diffs and or its a hypoid gear oil
Post Posted: Mon Aug 09, 2010 10:39 am
I've got a 4L bottle of hypoid gear oil in the garage, could I use it in the diff or is it just for LSD's?
Post Posted: Mon Aug 09, 2010 10:49 am
the Vmx80 say's not to use in hypoid's, but can't remember seeing it in the multitrac.
Post Posted: Mon Aug 09, 2010 9:08 pm
Hino diff oil works great in everything but engine.
Post Posted: Tue Aug 10, 2010 6:52 am
It says on the back.
"Castrol Multitrax is particularly suitable for vehicals with combined manual transmission and hypoid differentials."
Im not sure what this means.
Post Posted: Tue Aug 10, 2010 6:54 am
You can use it in diff's, but was designed for transaxel's ( front wheel drive g/box's)
It will be fine in all your running gear..
Vehicle: LJ20 LJ50
Post Posted: Tue Aug 10, 2010 8:34 am
Special gear oils are required for hypoid gears because the sliding action requires effective lubrication under extreme pressure between the teeth.
Camels have nice toes
Post Posted: Tue Aug 10, 2010 1:32 pm
i just use extra virgin olive oil.
the bonus is if you ever need some oil for you frying pan while on a camping trip and you've forgotten it, you can undo the diff bung a bit and let some out in your pan. 8)
Users browsing this forum: No registered users and 223 guests
