It is currently Thu Oct 01, 2026 5:19 am
Post Posted: Mon Aug 09, 2010 7:09 am
My rear diff is whining big time (probably didnt get to the diff pinion seal in time) and now I thinking the best option would be a lockrite any views would be appreciated, Couple of questions thou
1 Are they only available thru locktup
2 Do they make steering heavier
3 Should I but the coupled unit or without coupler
4 How much on average to install
Post Posted: Mon Aug 09, 2010 7:13 am
A lockright in the rear diff wont make your steering any heavier.a front one will :wink:
also if your planning on putting it in the same rear diff you alrerady have it wont fix the whine unless you rebuild the diff.
1 lowrange offroad $189
2 you only need couplers if your side gears are shot , I wouldnt bother
3 they work well in the rear but im not really a fan of them in the front diff but they do work.
Post Posted: Mon Aug 09, 2010 7:24 am
thanks for the info
Post Posted: Mon Aug 09, 2010 7:49 am
Please explain.. are you talking about the coupler or the locker??
:P
Post Posted: Mon Aug 09, 2010 7:58 am
:P
thanks stecky, that would be the locker in the front :wink:
Post Posted: Mon Aug 09, 2010 8:01 am
Thank you :P
Crunched run's a lockrite in the front & can't turn thing's I do with ease, so that's enough to put me off a front.... unless it's air.. 8)
rear tho.. :P
Vehicle: Sierra Utey!
Post Posted: Mon Aug 09, 2010 8:36 am
steknig wrote:
Thank you :P
rear tho.. :P
What he said. If you can afford it, go airlockers in the front - but if it's a rear we're talking about, just weld the farker.
My ute..
Post Posted: Mon Aug 09, 2010 12:19 pm
Crunched wrote:
steknig wrote:
Thank you :P
rear tho.. :P
Lockright and PS works fine in mine.
Post Posted: Mon Aug 09, 2010 8:30 pm
Red89 wrote:
Crunched wrote:
steknig wrote:
Thank you :P
rear tho.. :P
yes red I agree in part.
lockrights lock just fine in the front but the problem is that they dont unlock the best in the front either. As a cheaper locker they work just fine I had a front and rear lockrite for a long while.
but having had both if I were to do it all again i'd run a rear in a heartbeat I think they are a great product for the rear but I'd hesitate to put one in the front as the torque steer and lack of steering when under power gave me the shits. I'd save for a selcetable locker.
And yes power steering makes a front lockrite much more bearable
Post Posted: Mon Aug 09, 2010 8:57 pm
my rear lockright is the one that shits me. my front works great(1510 in a 2 pin center)
but i think my next mod is gunna be a rear air locker.
Users browsing this forum: No registered users and 127 guests
