It is currently Thu Oct 15, 2026 2:11 pm
Post Posted: Mon Aug 09, 2010 11:44 pm
After wheeling the other day nothin serious just messing around.
I noticed my front driver wheel has a wobble to it when I'm going over
bumps and turning and there is a rattle somewhere in the front
I jacked it up and shook everything I could grab. Nothing seems loose
Any ideas?
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Tue Aug 10, 2010 12:54 am
Search wheel wobble. That will give some idea's.
You sure the wheel isnt buckled? Spin it in the air.
Post Posted: Tue Aug 10, 2010 2:43 am
i had something good happen in my sierra. When i'd turn and apply the breaks, the break peddle would pulse up and down. Turns out i had stripped a few wheel nuts. Maybe check that they are all ok. I had 2 that were tight, & 3 that were stripped. So it seemed tight, until i cornered.
Download Sets @ http://www.johnpaul.3leggedcat.net
Post Posted: Tue Aug 10, 2010 3:13 am
Yer tried the search but everyones wobbles were with speed mine does it going slow as i'll Jack it up an check tie rods and shackles
I have extended shackles that are close to vertical would this cause problems
Post Posted: Tue Aug 10, 2010 3:20 am
Vertical shackles will cause alot of other problems, not slow wheel wobbles. Have a look at your avatar.. Normal shackles will make that rear wheel stay on the ground..
May i suggest you just don't look at your wheel when off road..? :lol:
Everything to do with wobbles at speed has to do with slow speed wobbles also! Go through the list. Make sure everything is secure. It might be just play in the steering.
Does your left wheel do the same?
Post Posted: Tue Aug 10, 2010 5:52 am
Havent checked left wheel need a passenger for that will do it tonight. Where do you get standard shackles or should I make some?
Post Posted: Tue Aug 10, 2010 10:25 am
Misses told me the passengers is wobbly aswell whats the next step from here
Post Posted: Tue Aug 10, 2010 1:34 pm
hmmm, get her under the car to investigate further.
Post Posted: Wed Aug 11, 2010 6:30 am
Hahaha should hay it's booked in for wheel alignment on monday they can figure it out and fix it for me hope it's not expensive
cheers for help
Post Posted: Wed Aug 11, 2010 9:32 am
mine wobbles over bumps, but thats how it is.
Post Posted: Wed Aug 11, 2010 10:08 am
I just won't look at it haha the rattle is worrying and un even were on the tyres wheel alignment sort that out
Post Posted: Wed Aug 11, 2010 10:11 am
Seriously this is the best advice in this thread
stop looking at your tyres, look where you are going before you get called stupid for asking stupid questions
Post Posted: Fri Aug 20, 2010 4:25 am
Had wheel alignment not that it has changed much. asked them to find rattle they said it was bonnet hinges being loose so tightened them rattle still there. My front brakes wobble a bit think this may be the cause tightened them and regreased them. They still hve some play in tem are they fucked or
is this normal?
Post Posted: Fri Aug 20, 2010 4:32 am
Are your discs warped?
Post Posted: Fri Aug 20, 2010 4:44 am
I haven't checked I should when I got it the pads were bare metal on driver side, this would warp them yes?
Users browsing this forum: Google [Bot] and 252 guests
