It is currently Sun Sep 20, 2026 11:54 pm
Post Posted: Tue Aug 10, 2010 7:52 am
was going to upgrade front brakes in my sierra to vitara calipers and vented disc.
Can get calipers of a 97 vitara. Does it need to be of a lwb, or are the calipers the same on all vitara's?
Thanks for any help
Post Posted: Tue Aug 10, 2010 8:06 am
is it a 1.6 with vented rotors?
Post Posted: Tue Aug 10, 2010 8:07 am
Thanks for any help
As long as the calipers are off a 1.6L LWB with vented rotors you should be fine.
The 2L have bigger brakes and will need 16" wheels with the right offset to clear them. :roll:
Post Posted: Tue Aug 10, 2010 8:52 am
LWB 1.6 front disc and callipers are what you need. They are a bolt on but the backing stone guard needs trimming to allow for the bigger calliper. And you will need help to bleed properly as you need to unbolt the caliper and rotate it a bit to bleed as bleed valve is in the wrong spot for the sierra.
Post Posted: Tue Aug 10, 2010 9:40 am
Mine bolted straight on..
Post Posted: Tue Aug 10, 2010 11:38 am
so did mine but i had to trim a bit of the stone guard off. 30 secs with some tin snips was all it took.
Ive got a pic somewhere
Post Posted: Tue Aug 10, 2010 12:43 pm
I was expecting to have to trim, but none needed.. 8O
Post Posted: Tue Aug 10, 2010 1:13 pm
thanks for the help, are the 1.6 of a swb the same too?
Post Posted: Tue Aug 10, 2010 1:15 pm
No, has to be Lwb to get the vented..
Post Posted: Tue Aug 10, 2010 1:16 pm
These are the same as a sierra.
Users browsing this forum: No registered users and 221 guests
