| jimny death shake http://auszookers.com/forum/viewtopic.php?f=5&t=14322 |
| Author: | dangerousdog [ Sat Aug 14, 2010 1:05 pm ] |
| Post subject: | jimny death shake |
hay all went out on a night run havent been on one for a bit forgot how fun thay are. Well all was good till i got to the hill anyony have this happen befor |
| Author: | Benz [ Sat Aug 14, 2010 1:46 pm ] |
| Post subject: | Re: jimny death shake |
bent something? :S |
| Author: | Zooksta [ Sat Aug 14, 2010 2:42 pm ] |
Probaly some mud inside the rims that unbalanced it. Mine gets the shakes bad at about 70 kmh when the wheels need balancing, scary shit |
| Author: | royce [ Sat Aug 14, 2010 9:27 pm ] |
If the steering wheel isnt where its supposed to be youve bent something, likely the steering arm between the 2 wheels |
| Author: | Lockie666 [ Sun Aug 15, 2010 3:42 am ] |
royce wrote: If the steering wheel isnt where its supposed to be youve bent something, likely the steering arm between the 2 wheels
X2 |
| Author: | dangerousdog [ Mon Aug 16, 2010 8:04 am ] |
well i bent somthing its the rod that go's from the diff to the chasis what is that one called and anyone no where i can find one im down geelong (vic) and cant find one |
| Author: | atari4x4 [ Mon Aug 16, 2010 8:10 am ] |
sounds like the panhard rod is bent, it's the one that isn't attached to the steering! |
| Author: | dangerousdog [ Mon Aug 16, 2010 8:13 am ] |
thats the one |
| Author: | dangerousdog [ Thu Aug 19, 2010 9:37 am ] |
ok i got a new panhard bar today from tough dog looks to be the goods http://www.toughdogdealer.com.au/jimny.htm looks ezy to put in just 2 bolts but is there anything i should know befor i give it a go???? thanks |
| Author: | steak_knife [ Thu Aug 19, 2010 10:47 am ] |
Keep an eye on the locking nut, thay have a coarse thread & like to come undone.. |
| Author: | atari4x4 [ Thu Aug 19, 2010 11:00 am ] |
if it's adjustable, adjust it so it's the same length as the original one from hole to hole before you fit it. |
| Author: | steak_knife [ Thu Aug 19, 2010 11:09 am ] |
atari4x4 wrote: if it's adjustable, adjust it so it's the same length as the original one from hole to hole before you fit it.
What if it's lifted tho?? |
| Author: | 96coily [ Fri Aug 20, 2010 7:17 am ] |
steknig wrote: atari4x4 wrote: if it's adjustable, adjust it so it's the same length as the original one from hole to hole before you fit it. What if it's lifted tho?? It'll get him close |
