http://auszookers.com/forum/
1.6 EFI
http://auszookers.com/forum/viewtopic.php?f=5&t=1433
Author:  Sneakyzook [ Thu Oct 18, 2007 11:49 pm ]
Post subject:  1.6 EFI
Anyone done one of these for a Sierra???
traps?????
mods?????
Advice...
For those who have tried or investigated, Is it worth it?
SZ
Author:  royce [ Fri Oct 19, 2007 12:01 am ]
Post subject:  Re: 1.6 EFI
just buy a vit with one in it :wink:
Author:  Sneakyzook [ Fri Oct 19, 2007 12:04 am ]
NAH not cool enough 8)
I think it is gonna be a pain but it should be worth it.
Author:  steve [ Fri Oct 19, 2007 12:13 am ]
have you got the stuff sneaky? tell!
Author:  Sneakyzook [ Fri Oct 19, 2007 12:24 am ]
errrrr not yet, but i will.
i need to talk to someone whos done it. ive been keen for a while. my 1.3s gonna pak it in when im miles from nowhere.
last night i was watching the briz31 tube, there was a dude on there forked out $1000 for a tail shaft!!
3g for a lumpy 1.6 sounds ok 8)
Author:  royce [ Fri Oct 19, 2007 12:27 am ]
I think you should put twin webbers on it :)
Author:  Sneakyzook [ Fri Oct 19, 2007 12:40 am ]
ol scool :wink:
Author:  royce [ Fri Oct 19, 2007 12:47 am ]
would sound pretty cool though, suck to hook a snorkel up but
Author:  steve [ Fri Oct 19, 2007 12:55 am ]
projectzook did it, if you can track him down he might have some good info
Author:  sp1086 [ Fri Oct 19, 2007 10:39 am ]
I got a tail shaft cut and welded to length for my Carry Van which I put a 1L & 5 speed in which was a upgraded from the 800cc & 4 speed. That only cost $150 to get the tail shaft cut, a different yoke put on the front + balence and they even painted it black..lol Thanks Gibbs truck parts on the Gold Coaat. :D
If your going to use your standard 1.3 box and transfer you shouldn't need to worrie about it anyway. Arn't the 1.3 & 1.6 blocks the same? :?
If you go ahead with it you'll have sooo much more power.. ;)
Author:  tanshi [ Fri Oct 19, 2007 12:41 pm ]
I did the 1.6 Baleno into my sierra. what did you wanna know?
Author:  Sneakyzook [ Fri Oct 19, 2007 5:25 pm ]
mate if you had to got through it again would you? Is it worth it?
How much of an outlay should i be looking at?? Are balenos cheaper.
Author:  tanshi [ Fri Oct 19, 2007 5:52 pm ]
My baleno one was a 2002 engine, ie newer than most vit ones you will get. A little bit more work cos its out of a FWD car. I would do it again and am currently looking into if i can do another one into an LJ81. The motor and adaptor to 1.3 gear box cost me $1800. FATZOOK off here also did one of these. I saw one go on ebay last week for $450 but i wasnt quick enough to bit on it.
Author:  Sneakyzook [ Fri Oct 19, 2007 7:01 pm ]
Thanks Tanshi OK good.
where did you get yours and how many kms did it have. Would you trust those on ebay?
have you got a list of the goodies i need like pulleys sump mods and stuff?
Author:  tanshi [ Fri Oct 19, 2007 7:13 pm ]
this one was down on the gold coast, and was a half cut so i would have trusted it coz i would have gotten it running before i payed for it. I bout mine through some one on NBS4x4 , they bought it from a wreckers, mine had 60000 on it when i bought it. The sump i modified grafting in a piece from the baleno one into the front of the 1.3, the bolt patterns are the same, but the baleno has a crank shaft sensor. there are slight changes to be made to the engine 1.3 mounts. Wiring was the hardest part but in any efi swap it will be
Author:  Sneakyzook [ Sat Oct 20, 2007 1:06 pm ]
did you have a body lift? are there any parts beside the sump that need modification.
Was you baleno engine a twin OHC?
Author:  tanshi [ Sun Oct 21, 2007 12:13 pm ]
The radiator hoses are non standard, but we just looked at what we needed and picked up some to suit from supercheap. I didnt have a body lift at the time and the fit without was great. Having recently body lifted i realised how much easier things would have been if i had done that first. There are a few little things that need doing which i cant think of right now, It is not a bolt in job, but it was well worthit IMHO.
Author:  Sneakyzook [ Sun Oct 21, 2007 3:00 pm ]
Thanks again Tanshi do you know anything about the escudo engine , like do i need a bl with this engine?
Author:  tanshi [ Mon Oct 22, 2007 12:07 am ]
its a Vitara 1.6. slightly easier to fit, but not as new.
Author:  Sneakyzook [ Mon Oct 22, 2007 12:18 am ]
I had a look at one today. Like you said the wiring is going to be the biggest issue.
After talking, searching and listening Im prepared to pay someone to do the whole install job, It doesnt take much to go from a $2500 to a $3500 job if you fry the computer by hooking up the wrong wire..
Author:  Fatzook [ Mon Oct 29, 2007 4:28 am ]
I just did this conversion for a local club member and it came in at about $3500 when all said and done.
Author:  steve [ Sat Dec 22, 2007 11:58 am ]
got this done yet sneaky? :)
Author:  joshNZ [ Sun Dec 23, 2007 1:00 am ]
thats alot of money for a 1.6efi why bother put someting desent in there if u want more power,prob work out cheaper and wont throw a leg out of bed like alot of 1.6 efi's do
Author:  royce [ Sun Dec 23, 2007 1:09 am ]
like what?
where are all these legless 1.6's?
Author:  joshNZ [ Sun Dec 23, 2007 1:37 am ]
4age or CA18,
proberly at the tip now,but i no of a a few and seen a alot
u cant say youve never seen one do that its pretty coman by what ive seen
Author:  royce [ Sun Dec 23, 2007 2:24 am ]
never, not a single one
4age is a poorly built heavy piece of crap, they have bugger all power over a G16
C18 is an old engine that wasnt real good to start with
and neither fit in a sierra well
Author:  joshNZ [ Sun Dec 23, 2007 2:50 am ]
poorly built,they are a very strong motor,and are not much heavyer than a zook motor,4age being 100kw would help over the 75ishkw 1.6 power with the weight diff
and a ca would have more technology in it that a 1.6efi and a 1.6 efi isnt the newest motor only just newer than a ca
both with alot more after market extras and add ons than the zook motor
i think the money they sell for is a joke for what they are
Author:  royce [ Sun Dec 23, 2007 3:26 am ]
yeah they are dear, doesnt mean the others are better
I should go get some pics of my brothers 4age graveyard, he even split a block once
