Just after some info in whats req'd to change the Passengers side Engine Mount...... and I guess also on the Drivers side as I will need to replace that one at some point in time....
Do I need to remove the Exhaust Manifold to give me better access? What's the easiest way of removing the old one and replacing it with a new one (ie with the engine still in the car obviously ::) )???
What sort of $$ are they worth and where's the best place to get them from.....
I rang Ripco and they want $100 each
Any "good" advice will be appreciated <ii>
(PS: I assume the VL Engine Mounts are not the same as a Vitara ones ???)
cheers....
rob
_________________ '93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
i just used a crane and a block of wood between engine then jacked it up just enough to get old one out new one in prob not the best way to do it but worked for me
Users browsing this forum: No registered users and 232 guests
