| Maruti engine swap http://auszookers.com/forum/viewtopic.php?f=5&t=14347 |
| Author: | xedent [ Sun Aug 15, 2010 10:02 pm ] |
| Post subject: | Maruti engine swap |
I have just got myself a 90 model maruti, reading about it I can't really understand what it's got. Can anyone tell me what's required to fit a 1.3 or better yet a 1.6 efi. Cheers |
| Author: | want33s [ Sun Aug 15, 2010 10:11 pm ] |
| Post subject: | Re: Maruti engine swap |
To fit a 1.3 you'll need to move the engine mounts or replace with 1.3 mounts. To fit a 1.6 you can use an adapter kit that will bolt up to 1.3 mounts. Gearbox tunnel will need enlarging a bit to fit 1.3 box. Wiring, radiator mounts, airbox, exhaust is all different too but easily overcome. |
| Author: | xedent [ Sun Aug 15, 2010 10:19 pm ] |
Cheers for the reply if you have to enlarge the tunnel are you better to use a vitara 5 speed ? |
| Author: | want33s [ Sun Aug 15, 2010 10:35 pm ] |
xedent wrote: Cheers for the reply if you have to enlarge the tunnel are you better to use a vitara 5 speed ?
You'd have to enlarge it even more to fit a VIT 5 speed and then you'd have to use the VIT transfer or adapt the box to run a jackshaft to a Sierra transfer.. Lots more work.. Oh and gearbox mount would need work too. |
| Author: | xedent [ Sun Aug 15, 2010 11:05 pm ] |
So best way would be to take body off chasis to do it ? |
| Author: | want33s [ Mon Aug 16, 2010 12:26 am ] |
xedent wrote: So best way would be to take body off chasis to do it ?
I reckon that would make the mods easier to undertake. |
| Author: | Chopz [ Mon Aug 16, 2010 1:33 am ] |
Mate have a chat to Mr Rocky on here. He's got a 1.6L Baleno engine in his maruti and he did all the work himself. Im guessing you have a 4spd box? In which case the 5 spd guts from a 1.3L fit into the maruti 4 spd case. Not sure on how that would go matching up to a vit or baleno engine, but another option. |
| Author: | xedent [ Mon Aug 16, 2010 1:35 am ] |
Can anyone tell me where to find a wiring diagram for my maruti dash etc. |
| Author: | joeblow [ Mon Aug 16, 2010 2:23 am ] |
want33s wrote: Gearbox tunnel will need enlarging a bit to fit 1.3 box. not needed. the maruti has a 1.3 tunnel. |
| Author: | xedent [ Mon Aug 16, 2010 2:40 am ] |
joeblow wrote: want33s wrote: Gearbox tunnel will need enlarging a bit to fit 1.3 box. not needed. the maruti has a 1.3 tunnel. Is this on the first maruti's ? Is |
| Author: | xedent [ Mon Aug 16, 2010 2:45 am ] |
Anyone know what wiring diagram I need for the dash of my maruti |
| Author: | want33s [ Mon Aug 16, 2010 3:50 am ] |
xedent wrote: Anyone know what wiring diagram I need for the dash of my maruti
Not real sure but I would say that 1.0 Sierra would be damn close. |
| Author: | xedent [ Mon Aug 16, 2010 7:24 am ] |
want33s wrote: xedent wrote: Anyone know what wiring diagram I need for the dash of my maruti Not real sure but I would say that 1.0 Sierra would be damn close. Anyone got one ? |
| Author: | want33s [ Mon Aug 16, 2010 8:02 am ] |
www.suzukiinfo.com |
| Author: | MrRocky [ Tue Aug 17, 2010 4:56 am ] |
* i used 2" body lift to clear bonnet (not sure if necessary) * maruti g/box yoke fits the 5spd * 5spd bolts to 4spd mounts * j/shaft is the same * radiator mounts are different and rad is smaller on maruti * fire wall may need a bit of a bash with a hammer to clear motor (for baleno) * i used 1.6 fusebox and loom and powered and earthed wires from the ecu pinout diagrams (pj zook has these i think) * sump and pick up may need to be swapped and modded (mine was already done) * engine mounts are totally different for 1ltr ( i used 10mm plate bolted to standard mounts as per christovers mounts on outerlimits * exhaust manifold is different * I used a carby lift pump feeding an efi (maybe vl) pump where the fuel filter was near the tank on the chassie and relocated the filter to engine bay. thats all i can recall of the top of my head |
