Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
drovin
Joined: Fri Mar 05, 2010 10:30 pm Posts: 39 Location: paringa
 Posted: Mon Aug 16, 2010 10:49 am |
was fitting my vit tank as part of a g16b install into 97 maruti, had the rear wheels off the concrete, on completion started the weapon up and bugger me the vss signal was activating my hand brake and battery dash lights. I copied Bron5on post and all else seems fine, ie tacho & engine check light. Have removed the dash and the issue seems to be coming from the earth screw of the vss. With the screw removed, no lights. The puzzling thing is the vss earth and the two lights earth are on a different circut. anyone had this issue ???
drovin
 Posted: Tue Aug 17, 2010 8:56 pm |
Ran an independent earth, isolating the dash earth , still got the flashes. Im runnining out of options and ideas, is it posible that the earth wire goes to the ecu??
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Aug 18, 2010 12:08 am |
Put a fibre washer under the VSS screw.
bazook
Joined: Sat Jul 12, 2008 11:30 pm Posts: 1082 Location: brisbane logan
 Posted: Wed Aug 18, 2010 12:43 am |
I did the same as damo and seems to be working just fine so yea do what jas said put a fibre washer on it
damo's diy vss install
drovin
 Posted: Wed Aug 18, 2010 9:42 am |
cheers guys, fitted the fibre washer and still got the blinks, The issue is coming from the earth screw, fibre washer under earth screw solves it, but as soon as i earth it, problems back
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 259 guests
