It is currently Sat Oct 17, 2026 10:09 am
Post Posted: Tue Aug 17, 2010 12:27 am
I am led to beleive that this block conversion has been acheived, I still want to use all the top end, and all from the G1.3bb :roll:
Any help appreciated Bill
Post Posted: Tue Aug 17, 2010 1:34 am
It has been done.
Any reason why you only want to swap the bottom end?
Post Posted: Tue Aug 17, 2010 1:50 am
:D Was trying to simplify,, seems easier to do just the bottom end without getting into the elecronics... ?? Bill
Post Posted: Tue Aug 17, 2010 2:03 am
I have heard this has been done with a baleno block, Unsure of any issues during build though..
Post Posted: Tue Aug 17, 2010 2:07 am
Im pretty sure Alien has this set up in his sierra
Post Posted: Tue Aug 17, 2010 2:08 am
Um a G13BB is from a jimny ay :?
Post Posted: Tue Aug 17, 2010 2:11 am
Aliens got a vit motor.
G13bb is early jimny motor
early jimny
Post Posted: Tue Aug 17, 2010 2:14 am
Yeah a vit 1600 block with a jimny top end :wink:
Post Posted: Tue Aug 17, 2010 2:15 am
early jimny
Armsup its not often im right :lol:
Post Posted: Tue Aug 17, 2010 2:19 am
[i]I forgot to mention that this convert is anticipated on a '99 jimny G13bb Auto..... Bill
Vehicle: '92 Sierra
Post Posted: Tue Aug 17, 2010 2:24 am
Hows your clearance between the head and bonnet as is? Obviously the G16 block will make the engine taller.
Post Posted: Tue Aug 17, 2010 2:39 am
Give Suzistore a call they just had a jimny with a 1600 bottom end conversion in there shop a few weeks ago
The jimny mentioned above didn't have a body lift so i dont think it would be to much of a problem
Vehicle: '92 Sierra
Post Posted: Tue Aug 17, 2010 2:46 am
Oooooh haven't been around for a while. I thought Alien had a sierra.
Post Posted: Tue Aug 17, 2010 3:01 am
He does have a sierra, with a 1600 block and jimny top end
Post Posted: Tue Aug 17, 2010 6:11 am
yeah i run that in mine - im using the suzistore adaptor kit for g16 bottom end, jimny bb top end and computer etc... it means you get to keep the airbox and everything the same and lets you run a purchased snorkel. It also keeps the engine bay very tidy.
Mines in a sierra and no bodylift - it doesnt sit that tall compared to when i had a weber on the top (i had to cut the bracing out of the bonnet to make it fit).
I think your biggest hurdle is an adaptor kit for a 1.6 in a jimny... but im sure someones made them, or at least knows how. If you get stuck www.suzistore.com.au can fab them - and they know suzukis very well!
Post Posted: Tue Aug 17, 2010 6:29 am
Thanks for all your inputs. I will get in touch with suzistore and see what they can come up with..
Hey Alien What is the performance like ? I anticipate it to be better than a straight G16 ??
Regards Bill
*JIMNY*
'99 G13BB, Auto, White.
Post Posted: Tue Aug 17, 2010 6:34 am
i went from g13a to g16a... that was a massive difference! then about a year and a bit later i put a weber on, another huge difference.. then years later its now efi using the jimny top end and its the difference between 1.3 and 1.6 all over again... it feels like torque has doubled. power feels about the same as the weber but far torquier (is that a word?)... i dont think anyone would ever regret it.
Not sure on straight g16b, but it would put out more power i'd think - the torque band would be questionable though - you'd assume its max torque would be higher in the rev range when compared to a frankenstein style g13bb/g16 engine.
Oh - and dont forget you need to use g16b pistons in the bottom end - so you can use a g16a bottom end but need to change pistons over.
Post Posted: Tue Aug 17, 2010 8:10 am
Thanks Alien, Hey I might be back to 'pick your knowledge' some more.
Regards Bill
*JIMNY*
Post Posted: Tue Aug 17, 2010 8:39 am
Same as sierra. The BB box bolts into a sierra. Even the internals are interchangable with sierra.
Post Posted: Tue Aug 17, 2010 8:41 am
Regards Bill
Power of G16B would be more. Same with the torque. But the difference would not be more than 5kw I would imagine.
Post Posted: Tue Aug 17, 2010 8:57 am
OK so now I am up to fitting a G16B block in place of my G13BB, still using the G13BB top end and Electronics... The next prob could be fitting up to the Auto box???
Regards Bill
WANTED: G16B Bottom end complete, any cond considered, will rebuild, if necessary........................... < billrogers@live.com >
*JIMNY*
Post Posted: Tue Aug 17, 2010 9:24 am
Auto will fit the same as the manual will.
PM BenT. He makes the adaptors.
Post Posted: Tue Aug 17, 2010 9:35 am
i did the exact same conversion about 5 years ago , but i didnt use an adaptor plate as i looked closely at how the torque convertor drove the pump in the transmission , the tangs dont go in that far to start with , then pulling them out an extra what 5-6mm , didnt want to risk it.
modified the bellhousing to bolt to the 1.6 engine , its no big deal as even if the trans needed changing , the bellhousing unbolts and can be swapped over.
1 more thing , alignment is absolutely critical with the auto , i didnt quite get it right the 1st time , and it broke a flex plate every 1000km's , took 2 broken flex plates to figure something wasnt quite right , the alignment was out about .5mm!!
Post Posted: Tue Aug 17, 2010 11:49 pm
I was also referring to engine mounts, theres adaptors for that too...
Post Posted: Wed Aug 18, 2010 1:08 am
got ya :wink:
Users browsing this forum: No registered users and 183 guests
