It is currently Mon Oct 19, 2026 6:53 pm
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Tue Aug 17, 2010 7:04 am
Guys.....
Just after some info in whats req'd to change the Passengers side Engine Mount...... and I guess also on the Drivers side as I will need to replace that one at some point in time....
Do I need to remove the Exhaust Manifold to give me better access? What's the easiest way of removing the old one and replacing it with a new one (ie with the engine still in the car obviously ::) )???
What sort of $$ are they worth and where's the best place to get them from.....
I rang Ripco and they want $100 each
Any "good" advice will be appreciated <ii>
(PS: I assume the VL Engine Mounts are not the same as a Vitara ones ???)
cheers....
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Tue Aug 17, 2010 7:23 am
http://www.suzistore.com.au/shopexd.asp?id=1602
Look's the same as a Vl to me..
you'll need to lift the eng off the mount's, after undoing the 14mm nut first of corpse.. :P
Post Posted: Tue Aug 17, 2010 7:42 am
i just used a crane and a block of wood between engine then jacked it up just enough to get old one out new one in prob not the best way to do it but worked for me
Post Posted: Tue Aug 17, 2010 9:01 am
Are Commodore & Vitara Engine Mounts the Same ???
Post Posted: Tue Aug 17, 2010 9:05 am
I think the VL mount has a little knoby bit that you have to cut off but other wise they are the same
Post Posted: Tue Aug 17, 2010 6:40 pm
you have to unbolt the mount with 3 bolts in it take it out of the car then get the engine mount out.
Users browsing this forum: Google [Bot] and 409 guests
