It is currently Sat Oct 17, 2026 8:40 am
Post Posted: Tue Aug 17, 2010 11:19 pm
Hey guys,
Pretty sure my front output shaft bearing has shat itself so i'm going to rebuilf the whole t-case (no idea of overall condition)
Just a qucik query though... do i need the full rebuild kit from low range or the standard one??? (See link below)
transfer rebuild options
I'm pretty sure the front output bearing is a needle bearing, that would mean i need the full rebuild, correct?
Cheers for your help guys!
Post Posted: Tue Aug 17, 2010 11:24 pm
all the input and output bearings are roller bearings. the needle bearings run inside a couple of the gears deeper inside. im pretty sure someone here sells the bearing. im in need of a kit also
Post Posted: Tue Aug 17, 2010 11:35 pm
Cheers Finlay, just wasnt sure, wanted to check before i spent the extra few hundred :P
Vehicle: MY2019 Jimny
Post Posted: Wed Aug 18, 2010 12:11 am
Weaves sells bearings.
Get an upgraded front output shaft while you are at it...
Post Posted: Wed Aug 18, 2010 2:17 am
