http://auszookers.com/forum/
Converting my 1.6 to efi or weber ?
http://auszookers.com/forum/viewtopic.php?f=5&t=14421
Author:  straty [ Wed Aug 18, 2010 11:42 am ]
Post subject:  Converting my 1.6 to efi or weber ?
Hey guys, i know this has been asked before and before you tell me to go search, i have and i've found some good info however, what i wanna know is this, if i already have a 1.6 8 valve carby engine in my sierra, am i better off putting a weber 32/36 conversion kit on it for $700 or getting a suzi baleno wreck or similar and bolting the head and computer into my sierra. i would prefer this to changing out the entire motor as the engine in it only has 80,000k's on it. Also how hard is the swap, im a 3r year apprentice marine mechanic so im pretty competent ? so its either $700 for 100 year old technology that is temperamental on inclines or probably $800 for EFI ?
Thanks in advance
Jonny
Author:  Fatzook [ Wed Aug 18, 2010 11:44 am ]
Post subject:  Re: Converting my 1.6 to efi or weber ?
Thanks in advance
Jonny
Webbers are shit.
And the baleno is a 16V, so you would need to change the pistons in your 8v before you could fit the baleno head.
Easier and cheaper to buy said Baleno, fit that motor, then sell your G16a to recoupe some money.
Author:  straty [ Wed Aug 18, 2010 11:47 am ]
ah so from that i can assume the 8v is free running and the 16v is interferance ? just out of curiosity what makes you say the webers are shit ?
Author:  JrZook [ Wed Aug 18, 2010 11:50 am ]
How about the throttle body injection that did come out on some 1600's? Webers arn't that bad at all unless your always driving extreme angles. Mine ran beautifully for the 4 or so years I had it. No dramas what so ever!
Author:  Fatzook [ Wed Aug 18, 2010 11:52 am ]
Both are non interference, unless you have 8v pistons under a 16v head :wink:
Webbers are great for onroad, but unless you REALLY know your shit when it comes to webbers, you will have flooding issues on hills and sideangles when offroad. The 8v vitara carb is a better choice for offroad use IMO.
Peter
Author:  stockman [ Wed Aug 18, 2010 11:53 am ]
Better than efi?
Author:  straty [ Wed Aug 18, 2010 11:57 am ]
so you would reccomend either the baleno or vitara 1.6 EFI over an 8 valve with a Weber ? JrZook: i havent seen that system is it any good/ parts availablilty ?
Author:  Gwagensteve [ Wed Aug 18, 2010 11:58 am ]
Pretty much answered your own question there.
I's been proven over and over. Carby and EFI might make the same outright WOT power on a dyno, but real world, EFI is outstandingly better.
Author:  royce [ Wed Aug 18, 2010 11:59 am ]
i'd go teh full baleno conversion, then sell your 8 valve to somebody
getting the engine that cheap it probably wont cost a whole lot all up
Author:  straty [ Wed Aug 18, 2010 12:14 pm ]
ok cool looks like efi's the way to go also with the conversion can the standard sierra tacho be hooked up to the baleno motor, and in regards to the computer wiring am i best to use the standard ignition switch and stuff or use the efi stuff ?
Author:  alien [ Wed Aug 18, 2010 1:56 pm ]
sierra tacho can be hooked up - mine is - but a proper instrument place made the converter box for me. Only cost $80.
