| Quick question! RE: Headlights http://auszookers.com/forum/viewtopic.php?f=5&t=14436 |
| Author: | Glavas [ Thu Aug 19, 2010 8:31 am ] |
| Post subject: | Quick question! RE: Headlights |
How the fuck do I get the headlight globe out? I've got somewhere I need to be, am trying to get this globe changed before then, it's raining and I've got to do it outside because the sierra is too tall to fit under the roller door. Please explain. |
| Author: | ajsr [ Thu Aug 19, 2010 8:36 am ] |
| Post subject: | Re: Quick question! RE: Headlights |
if its a sealed beam you don't the headlight is the globe. otherwise it will be an H4 held is by a spring wire |
| Author: | Glavas [ Thu Aug 19, 2010 8:38 am ] |
You gotta be kidding.. Yeah it's a sealed beam, I assumed it opens from the front. So what the hell do you do when it stops working? surely i'm not going to be replacing the whole assembly? |
| Author: | Chop [ Thu Aug 19, 2010 8:41 am ] |
10 bucks or less for a new sealed beam Chop |
| Author: | Zook_Fan [ Thu Aug 19, 2010 8:41 am ] |
yep replace the whole light, last one i bought was about $17.50 from repco |
| Author: | Fatzook [ Thu Aug 19, 2010 8:42 am ] |
Yep. Replace it |
| Author: | Glavas [ Thu Aug 19, 2010 8:42 am ] |
Next question, How's the whole assembly come out? lol. I've undone the 3 screws from the front, unplugged it, does the grill need to come out? |
| Author: | Fatzook [ Thu Aug 19, 2010 8:44 am ] |
Glavas wrote: Next question, How's the whole assembly come out? lol.
I've undone the 3 screws from the front, unplugged it, does the grill need to come out? Yep. If its a 1.3L the grill needs to come out. |
| Author: | Glavas [ Thu Aug 19, 2010 8:47 am ] |
Fatzook wrote: Glavas wrote: Next question, How's the whole assembly come out? lol. I've undone the 3 screws from the front, unplugged it, does the grill need to come out? Yep. If its a 1.3L the grill needs to come out. Oh for the love of god, this is a lot of work for just one headlight. |
| Author: | PJ.zook [ Thu Aug 19, 2010 9:16 am ] |
Its not that bad, simply unscrew the couple of screws in the grille and remove grille (i have cable ties not screws), then unplug the dud headlight at the back, then push the whole light inwards and rotate (you dont need to undo the three screws, if you do then you will have to readjust your headlights). Then swap the metal surround onto your new light, and reverse the process. |
| Author: | whincup [ Thu Aug 19, 2010 11:11 am ] |
that, or go to the wreckers and buy some headlight assemblys that arent the sealed type. a lot less hassle to fix bulbs... i grabbed one for my car sierra at a wrecker, but it has volvo written on it. from what i read, other cars such as patrols have the same size, therefore fit i THINK. although IMO you are better with the sealed type, no risk of water getting into the headlight, ive had a few bulbs shatter because of that... |
| Author: | royce [ Thu Aug 19, 2010 11:13 am ] |
real quartz globes wont shatter when wet |
| Author: | whincup [ Thu Aug 19, 2010 11:15 am ] |
well i only assume they shatter when wet, theyre only cheapish ones i grabbed from a servo on the way home from a track. which actually give the better, brighter lighting? sealed or non sealed? |
| Author: | Built4thrashing [ Thu Aug 19, 2010 11:19 am ] |
its prob ok just needs some new headlight fluid. B4T |
| Author: | alien [ Thu Aug 19, 2010 12:14 pm ] |
unsealed are usually brighter cos u can run higher wattage in them. |
| Author: | ajsr [ Thu Aug 19, 2010 12:34 pm ] |
alien wrote: unsealed are usually brighter cos u can run higher wattage in them.
can also fillup with muddy water pretty good too |
| Author: | alien [ Thu Aug 19, 2010 1:19 pm ] |
so i've found! |
| Author: | dank [ Thu Aug 19, 2010 1:23 pm ] |
ajsr wrote: alien wrote: unsealed are usually brighter cos u can run higher wattage in them. can also fillup with muddy water pretty good too not if you only drive trees! |
| Author: | Glavas [ Thu Aug 19, 2010 3:17 pm ] |
regarding the water, that's what killed my sealed ones |
| Author: | whincup [ Thu Aug 19, 2010 4:58 pm ] |
how?? |
| Author: | dominator [ Thu Aug 19, 2010 7:59 pm ] |
whincup wrote: that, or go to the wreckers and buy some headlight assemblys that arent the sealed type. a lot less hassle to fix bulbs... i grabbed one for my car sierra at a wrecker, but it has volvo written on it. from what i read, other cars such as patrols have the same size, therefore fit i THINK.
although IMO you are better with the sealed type, no risk of water getting into the headlight, ive had a few bulbs shatter because of that... patrol are sealed too. |
