It is currently Fri Oct 16, 2026 1:47 pm
Post Posted: Sat Aug 21, 2010 4:29 pm
Hey guys ive searched but came up blank, is there anyway that you can change the rear main without removing the gearbox? I know on a jeep people do it but this is a zook 8O .
Thanks again
1989 1.3ltr sierra hardtop. 2" lift small exo oran
Post Posted: Sat Aug 21, 2010 6:31 pm
Yes
remove the engine..
Sorry I couldn't resist..
It isn't that hard a job to remove the gearbox.lp
Post Posted: Sat Aug 21, 2010 9:35 pm
I very much doubt there is ANY engine that you can replace a rear main seal without detaching gearbox.....
Post Posted: Sat Aug 21, 2010 9:40 pm
On some cars you can change the clutch without removing gearbox if i remember correctly, but ya have to take box out to replace rear main. Its a piss easy job.
Post Posted: Sat Aug 21, 2010 9:52 pm
lot of holdens with 2 piece rope rear mains can be done with a special tool and dropping the sump
Post Posted: Sat Aug 21, 2010 9:57 pm
OK maybe dinosaur old grey and red shitboxes...
I should have been more specific and said...
"I very much doubt there is ANY engine with a one piece rear main seal that you can replace without detaching gearbox".
Post Posted: Sun Aug 22, 2010 12:22 am
the only way to do it without removing the g/box it to take out the motor :wink:
Post Posted: Sun Aug 22, 2010 12:31 am
Okay thanks guys box will come out,
You guys need to realise there are a lot of cars that are diff to zooks that have the 2 pieceand rope seals maybe it's just us dinousaur old guys that remember :oops: .
Haven't done the zook box before are all bolts easy to get to and any parts that i need to know before i pull it out? will do it when i do the tcase gears, should make it easier?
Thanks
Post Posted: Sun Aug 22, 2010 3:21 am
Peice piss to do mate.... All bolts are easily accessible... Wont take long at all..they are simple as to work on.
Will be easier with transfer case out..
its only really old school cars that have rope seals.. Not alot of people know about them.. I have only come across one in the 7 years I have worked on cars.. And that was on a 1976 fairlane
Users browsing this forum: No registered users and 233 guests
