It is currently Fri Oct 16, 2026 2:32 pm
Post Posted: Sun Aug 22, 2010 12:55 am
Hiya all,
I'm about to change the front brake pads on my GV. Is it necessary to use anti squeak grease or rubber grease?
I have the service manual and it says to use rubber grease on the cylinder slide pin/bolt. I've never used this grease before when changing pads in the past.
What about anti squeak grease? Where do I put this? I've read about this grease on this forum but there's no mention of it in the service manual.
Cheers,
Ben
2002 SWB GV
Lifted and Locked
Post Posted: Sun Aug 22, 2010 2:03 am
TheOtherLeft wrote:
Hiya all,
Cheers,
Ben
Did that come with the pad's?? Black or white grease??
If your slide's are still moving freely I wouldn't worry to much about new grease, if thay are a lil stuck I'd be inclined to clean them well & re-grease with either rubber grease or HTB( high temp bearing grease), most grease that come with gen pad's is for in between the pad & the caliper, the bit's that touch..
Post Posted: Sun Aug 22, 2010 3:12 am
I bought Bendix 4WD pads. They didn't come with any grease. I thought maybe I have to buy them extra???
2002 SWB GV
Lifted and Locked
Post Posted: Sun Aug 22, 2010 3:56 am
Bendix have a "anti squeal" pad on the back anyway, so as long as your slide's are still moving freely, fit em.. :P
Post Posted: Sun Aug 22, 2010 6:01 am
Cheers thanks for the advice mate.
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 201 guests
