It is currently Mon Oct 12, 2026 12:16 pm
Post Posted: Mon Aug 23, 2010 8:30 pm
My mate has a Cigweld WeldSkill 170 Inverter arc Welder with tig in his shed that he has never used. I tryed using it on the weekend and failed. I have never used a tig before. Trying to weld just black steel.
Anyone help me on what settings, what goes to - and what goes to + ?
cheers
Post Posted: Mon Aug 23, 2010 8:47 pm
(-) Negative is earth.
(+) Positive is the handpiece.
Set the regulator to about 10 litres per minute.
Sharpen the electrode to a point and have it just recessed in the nozzle..
Vehicle: 93 Sierra
Post Posted: Tue Aug 24, 2010 12:28 am
Don't touch the electrode to the weld pool ... if you do, stop and re-sharpen the electrode. Push the weld pool rather than pulling it, and just dab the filler rod in every second or so. Make sure you actually are running a shielding gas ... my bet is that if he has never used it, he likely doesn't have a shielding gas bottle hooked up - you'll get nowhere without it.
Vehicle: 1987 sierra tray back buggy
Post Posted: Tue Aug 24, 2010 12:53 am
what they said and try and try and try and then spit the dummy go back in 2 hours and try some more untill you finally get it to look semi like a bead then feel good about yourself hahaha. its hard to get to start with like oxy welding only harder.
Post Posted: Tue Aug 24, 2010 12:57 am
I do gave gas hooked up, when I tried to use it on the weekend when I pushed the button nothing would happen ?
My Maruti build, Click WWW
Post Posted: Tue Aug 24, 2010 1:16 am
plugged in at the wall? you may need to scratch start it by scratching the tip on the surface to strike an ark similar to ark welding
Post Posted: Tue Aug 24, 2010 1:33 am
jump on youtube, will help lots
Post Posted: Tue Aug 24, 2010 6:14 am
and make sure the metal that you are welding is cleaned, the cleaner the metal is the eaiser and better it is to weld.
Post Posted: Tue Aug 24, 2010 6:17 am
X2
I always linish the surface before TIGing. It really does help.
Also I have found that when TIGing aluminium, I get better results with a slightly dull electrode ( not sharpened to a point). MS and S/S both like a fine point.
On another note, what gas are you using?
Post Posted: Tue Aug 24, 2010 7:14 am
make sure you metal is clean.
Its much easier to weld.
fatzook next time you weld alloy give everything a wipe down with thinners before welding. it helps!
Post Posted: Tue Aug 24, 2010 7:18 am
personally I think unless you are welding aluminium alloys that tig is a waste of time and effort.
mild and stainless mig well and much faster
Post Posted: Tue Aug 24, 2010 8:18 am
moly likes TIG :D
Post Posted: Tue Aug 24, 2010 8:50 am
ok I'll give you moly but it migs ok too :wink:
Vehicle: nt sierra
Post Posted: Wed Aug 25, 2010 6:50 am
cheers
yeah trying to learn as well
i thought that the Tungston was meant to stick out about 5 to 10 mm.
What sort of amps/volts/whatever woult you use for 3mm steel and sheet metal?
i was told 150 amps? for 3mm but that was crazy hot. i then tried 45 and that seemed to suck as well.
Post Posted: Wed Aug 25, 2010 10:40 pm
3mm stainless should be fine at around 80-100 amps. depending on the weld prep etc. 1.2mm stainless with a outer corner weld with no penetration is done at around 25-30 amps with the torch pointing the heat to out side of the job to prevent any peno being blown through.
argon for gas and tungsten sharpened to a fine point with the tungsten sticking out around 5mm for a butt weld. 10mm for a fillet weld.
Web wheeler extroadinaire
Users browsing this forum: Google [Bot] and 275 guests
