It is currently Mon Oct 12, 2026 2:49 am
Post Posted: Wed Aug 25, 2010 9:56 am
So I know power steering conversions for sierra's has been done to death and I've searched, so please bare with me guru's :)
I am fitting a cressida box to a WT sierra and have recently realised the rag joint spacings are slightly off. Due to the fact the rag joint holes are reinforced with metal collets I can hardly slot it out (not that Im too keen on that). So im wondering what have other people done? Is there something from another vehicle or somewhere you can get them custom made or maybe even buy the materials?
Cheers, Aaron.
Vehicle: 1987 sierra tray back buggy
Post Posted: Wed Aug 25, 2010 10:07 am
when i did it i used a uni joint out of an old car i had cut and welded the stearing shafts to length and had a uni instead of a rag joint. perhaps you can get the stearing shaft from the cressida with the appropriate uni joint
Vehicle: nt sierra
Post Posted: Wed Aug 25, 2010 10:35 am
x2 with uni joint
Post Posted: Wed Aug 25, 2010 9:16 pm
You could always make a new rag joint to suit.. After all they are just a piece of crossply tyre.
Vehicle: MY2019 Jimny
Post Posted: Wed Aug 25, 2010 9:24 pm
Cheers, Aaron.
Know of any more cressida boxes anywhere?
Post Posted: Wed Aug 25, 2010 10:28 pm
I am pretty sure that any heating, cutting or welding of steering components is a big no no in the rule book.
Post Posted: Wed Aug 25, 2010 11:11 pm
True^ But look at the rest of his car..
Every steering box setup has a rag joint for vibration and slight movement between the chassis and body.
I don't run a rag joint, instead i machined up a plate to suit the vit uni to bolt to the sierra shaft with vit powersteer.
On sunday i had very loose steering, like 1/2 turn steering wheel, doing 80km/h. This is not good....
The uni was coming off the box spline! Been there more than a year though.
Post Posted: Thu Aug 26, 2010 12:35 am
Probably a dumb question, but what runs cross ply tyre's these days? Isnt everything steel radial? I've got some bald commodore rubber in the shed that I've never got around to throwing away, would something like that suffice?
I've come across one other in the local wrecking yard, I'll be going there today or tomorrow, so I can have a look. However I do know of a jimny P/S box for $350, which looking through the P/S threads seems cheap. In hindsight I should've done that, but my cressida box, pump and lines cost me like $100, so I'll put up with the fabbing I have to do.
Post Posted: Thu Aug 26, 2010 12:39 am
a rag joint is just rubber with canvas through it.
I wouldnt go to the extreme of cutting up a wire radial tyre for a small circle of rubber.
find a clark rubber or similar, they should have an offcut or something you can use.
Or next would be make a adaptor plate.
I don't feel more or less vibration with no rag joint.
Post Posted: Thu Aug 26, 2010 1:04 am
Lots of caravans & light trucks still run crossply tyres.... You'd get a used one for nothing from a tyre shop.
Post Posted: Thu Aug 26, 2010 4:28 am
true but at least im not gonna drive it on the road unlike the 90% of the suzis on here that aren't legal.
anyway it may be against the rule to cut and weld a mild steel steering rod its not going to make it any weaker if done properly and the talk has been turned to making home made rag joints how can that be legal and any safer than a bit of chop chop?
Post Posted: Thu Aug 26, 2010 4:37 am
i thought your suzi was road registered??
Post Posted: Thu Aug 26, 2010 4:41 am
hahahaha no way man that was a joke.
it was registered with those plates to my granddad about 7 years ago before he went to the suzi dealership in the sky. its been un registered for about 3 years now we just wanted to keep the plates so told the cops that we buried em with the old boy.
Post Posted: Thu Aug 26, 2010 4:44 am
ha ha ha nice one! :D
Vehicle: LJ20 LJ50
Post Posted: Thu Aug 26, 2010 6:54 am
any side wall from a tyre could be used as the steel belts are only in the tread. (of passenger tyres)
Since its on the farm maybe you could find an old tractor tyre ( old being rooted not being kept for a spare) and cut that up
Camels have nice toes
Post Posted: Thu Aug 26, 2010 7:50 am
conveyer belt material or does clark rubber sell cross ply rubber
Post Posted: Thu Aug 26, 2010 9:05 am
Please do, thanks.
Users browsing this forum: No registered users and 223 guests
