It is currently Mon Oct 12, 2026 3:46 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Wed Aug 25, 2010 10:27 am
i got bogged tonight towing my boat up a beach and to get out i started dumping the clutch
at 5000rpm in 3rd low and it got me thinking about broken trans cases. i have
no case reinforcing and standard mounts and have been flogging my trans case
for a bit over 2 years and have only broken 2 mounts. you would think that
dumping the clutch with 1600kg attached to the back of the car would show
up any weakness so i am starting to think that the cases that have broken
were maybe caused by gear wind up. does that make any sense? has anyone had a case fail on a lowish traction surface?
Post Posted: Wed Aug 25, 2010 10:33 am
Power is another contributing factor.
Post Posted: Wed Aug 25, 2010 10:43 am
haha power is something i dont have much off. :lol:
havent broken mine in 4 yrs of hard wheeling and abuse every w/end
the 1.6 16v might help it along a little though. well see...
Vehicle: 4wd
Post Posted: Wed Aug 25, 2010 10:59 am
Just to make this thread useful down the track, can someone explane gear wind up and what causes it please.
Watch out or you'll get sued.
Post Posted: Wed Aug 25, 2010 11:11 am
stick your zook in 4wd on dry concrete and air down the tyres.
now pull a doughnut, thats windup at its best
Post Posted: Wed Aug 25, 2010 11:17 am
I think a lot of the complaints about broken mounts has to do with inferior aftermarket mounts. The factory Suzuki ones seem to be much stronger.
Post Posted: Wed Aug 25, 2010 11:53 am
So very true!!! The aftermarket mounts for them are shait!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Aug 25, 2010 12:01 pm
Yeah that could be true.
But I used genuine mounts in my maruti, with 6.5 gears, and 36's, and I still blew mounts quite easily.
I guess there would be alot of contributing factors like driving style, type of terrain, type and size of tyres etc. So putting it down to only one thing; like wind-up; may be only half the story. :?
Post Posted: Wed Aug 25, 2010 12:11 pm
Ive never blown a mount since swapping to aftermarket solid mounts,before that I did 5 or 6 new stockers
Vehicle: MY2019 Jimny
Post Posted: Wed Aug 25, 2010 6:41 pm
Chris had his 6.5 case split in two just driving on a dirt road at about 30kph...
Post Posted: Wed Aug 25, 2010 10:08 pm
was it locked and driving in 4wd?
Post Posted: Wed Aug 25, 2010 10:57 pm
Pretty sure it was unlocked in 2wd.
Paging kryzmac...
Post Posted: Wed Aug 25, 2010 11:06 pm
i gave mine a hard time(1yr?), then i added a roctoyring just to insure the gears stay in the box..
Post Posted: Wed Aug 25, 2010 11:40 pm
You are running fairly large treads on your rig tho. All I'm saying is when I just got my rig on the road with the 4.9's and 30's I let the 1.6 just idle up a descent hill (minimal throttle input, max 1k rpm) and bang the brand new aftermarket mount burst (single side). The rubber just separated from the metal. Replaced this for a s/hand genuine mount then went out on a few other trips and broke the other two aftermarket mounts!! Same issue, rubber separating from the metal. The old single genuine one is still holding in fine tho.
Dan
Lil Foot!
Post Posted: Wed Aug 25, 2010 11:54 pm
haha yeah i am waiting for fatzook to make something :lol:
Post Posted: Thu Aug 26, 2010 12:22 am
well i have been thinking about pulling mine out and adding some strenght but i might not now..
i am going to get a rocktoy ring.. i also have a set of justcruzin 30mm lifted mounts to fit.
Post Posted: Thu Aug 26, 2010 12:29 am
Well thats going to take years..
Post Posted: Thu Aug 26, 2010 12:55 am
I'm going to make something up to strengthen it all just as a precaution, not going to give it the chance to break
Vehicle: 85 Suzuki Sierra
Post Posted: Thu Aug 26, 2010 6:07 am
Any thing wrong with using the body lift blocks like a fellow from here sells in kits?. I made some myself out of body lift stuff. Whats the reason behind continually replacing the rubber ones with more rubber?
Post Posted: Thu Aug 26, 2010 6:13 am
I use soild alloy one side and poly the other it seems to work fine
Post Posted: Thu Aug 26, 2010 6:31 am
i kept rubber as i wanted the bit that busts to be cheap. i haven't heard of
any cases failing with standard mounts.
Post Posted: Thu Aug 26, 2010 6:49 am
Cool, that's what i figured out thinking about it some more. Do you want a torn mount and fix that off road or a .. torn something else :). Preferably neither please.
Cheers.
Orange LWB Sierra
Post Posted: Thu Aug 26, 2010 7:25 am
replace a couple of stock mounts in a foot of victorian slop/ mud on the side of the track in winter.
then tell me how much you like replacing the odd mount :wink:
Post Posted: Thu Aug 26, 2010 7:28 am
It's nice up ere!!! :roll:
Post Posted: Thu Aug 26, 2010 7:35 am
haha there is a reason i live where i do. :wink: :lol:
Post Posted: Thu Aug 26, 2010 7:41 am
i drove with 6.5s for a year on 31s and rear locker,standard mounts and never broke a mount then added a roctoy ring and some gussets to help with any breakages.
another year on and now with twin lockers ive still never broken a mount and drive mostly rocky terrain,hate mud.
They looked suss when i bought the zook but i dont abuse my car
Post Posted: Thu Aug 26, 2010 7:45 am
Rather replace a mount out there than a cracked case....
I want my old sig back :(
Post Posted: Thu Aug 26, 2010 7:59 am
strange though Ive towed several suzukis out of tracks with blown stock mounts to some where they could replace the mount or bodge something togther but never had to recover a zook with solid mounts and a blown case yet. I guess there is always a first time. :roll:
Post Posted: Thu Aug 26, 2010 8:44 am
ajsr wrote:
strange though Ive towed several suzukis out of tracks with cheap aftermarket mounts to some where they could replace the mount or bodge something togther but never had to recover a zook with factory, Bridgestone branded mounts
My take is that stock factory mounts will stretch forever (so far the case will heit the floor, even with a 2" BL (really!) and the stock arms will eventually bend.
Cheap aftermarket (chinese) mounts will break.
Long side arms will bend with transfer gears.
Beef stock arms and mounts and the risk is the case could break at the mounting locations.
PS 1.0 transfer mounts are better than 1.3. they run 4 mounts rather than three and the case is more resistant to twisting as a result.
I've run stock, 1.0 arms with no reinforcing with urethane mounts in my car and they've never bent with 6.5 gears and plenty of hate.
You want something to give. You don't want it to be the case.
Users browsing this forum: No registered users and 266 guests
