It is currently Thu Oct 08, 2026 3:46 pm
Post Posted: Sat Aug 28, 2010 12:36 pm
got a sloppy shifter in my 95 sierra i have replaced the shifter bush just wondering if there was anything else to try i seen on a us web sit about the shifter bolt but this was a sales add with no info just wondering if any one else has had any trouble like this. at the moment it has around an inch or so play from side to side.
Post Posted: Sat Aug 28, 2010 1:14 pm
In the neck where the shifter bush sits, there is a small bolt that locates into the slot on the shfter. What condition is it in? If its worn, broken or missing you will get shite loads of play.
Post Posted: Sat Aug 28, 2010 1:55 pm
yep put a new bolt in mine the other day and the difference was amazing.
Post Posted: Sat Aug 28, 2010 2:01 pm
interesting - i should check mine!
so rubber boot off the stick and its accessible?
Post Posted: Sat Aug 28, 2010 2:10 pm
yep 12mm bolt directly behind the shifter,you see the shaft of it when the shifter is removed. be careful its not broken when you remove the shifter as the broken bit can fall into the box
Vehicle: Clown Car..
Post Posted: Sat Aug 28, 2010 2:52 pm
Because I tend to take pictures of anything....
dust/dirt boot off, bolt still inplace..
dust boot on, bolt removed.
Dust boot off, bolt removed.
broken bolt..(scuze the grime, I dropped it prior to the pic being taken)
Post Posted: Sat Aug 28, 2010 9:09 pm
cool will check it later on today are new bolts easy to get hold of or a order in part
Post Posted: Sat Aug 28, 2010 9:17 pm
They are easy enough to get new but if you have an old box laying around or can get access to one, then you can use the reverse lockout bolt out of the side of the tailhousing.
Post Posted: Sat Aug 28, 2010 9:19 pm
thanks will have to have a look and chase one up if its stuffed
Vehicle: MY2019 Jimny
Post Posted: Sat Aug 28, 2010 10:51 pm
Wawawiwa!
Users browsing this forum: No registered users and 174 guests
