Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
magnat
Joined: Sat Jul 28, 2007 11:30 pm Posts: 1066 Location: Southern Highlands N
 Posted: Mon Oct 29, 2007 3:22 am |
Are the standard Tow hooks on the Vitara strong enough to withstand being snatched?? '
If Not, I need to know what to get... I mean its not like I intend to get stuck but wish to know the Safe Area's on a Vitara for Recovery..
I have the D-Shackles (3.5T rated) and just want to know, If I have to get pulled out, are the stock Tow positions safe??
I know not to attach the D-Shackles to the Bumpers or the Bullbar but what area's are safe??
rodw
Joined: Sat Jun 09, 2007 11:30 pm Posts: 153 Location: Brisbane QLD
 Posted: Mon Oct 29, 2007 9:51 pm |
Have you got a towbar? Take the ball out and put your shackle through the hole the ball bolt was in. At the front use the D on the passenger side. It is strong enough to take the weight of the Vit, but don't use it to recover a heavier car.
Cant recomend using the rear loop as it was gone when I got my rig, torn off, not cut...
_________________ Rod W
92 Vitara JLX Wagon
magnat
 Posted: Tue Oct 30, 2007 12:55 am |
So recovery hooks are advised?? What do I get an anyone have a clue as to how much?'
rodw
 Posted: Tue Oct 30, 2007 1:30 am |
There really is not anywhere to mount recovery points easilly. The best spot for D-shackles is the tow bar tongue at the rear and the front loop. That costs nothing if you have the tow bar. If you don't have a tow bar, try and mount a hook into the threaded holes in the rear chasis rail where the tow bar bolts on. You'd need an adapter plate made up to do this.
Just never hitch off a tow ball as there are a few deaths each year hitching off the ball when the ball breaks off. Thats why I say take the ball out and put the shackle where the ball was.
One day, I'll build a rear bar and incorporate a rear hitch and recovery points, not so sure about the front cos I have got a good bull bar so won't be putting an ARB bar with recovery points built in for a long time.
the recovery hooks are only about $20, but where to mount it might cost more.... so the tow bar is a good option. I have seen a hook mounted on the tow bar where the tongue bolts on.
92 Vitara JLX Wagon
BAZZOOK
Joined: Sat Mar 24, 2007 10:30 pm Posts: 1052 Location: MORNINGTON. VIC
 Posted: Tue Oct 30, 2007 11:28 am |
4X4 WRECKERS USUALLY HAVE BINS FULL OF HOOKS. JUST BUY SOME HIGH TENSILE BOLTS AS WELL
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 57 guests
