It is currently Sat Nov 14, 2026 12:25 pm
Post Posted: Mon Nov 19, 2007 1:34 am
As most of you know mine is off the road geting all fixed up after my last trip....... :twisted:
I took the spare off the back boged all the holes and under coated it but after marsheling i like the look of the no rear door and tyre mounted at the back on an angle sort of sticking just out of where the rear door would of been!
I'll get picks tomorow of what i mean but most would know what i mean if you have been to a comp!
So my question is is it legal to run with no back door?(Mine was a soft top so just the tail gate bit!) Can't really see why not? :?
CHEERS
back in a built sierra!
Post Posted: Mon Nov 19, 2007 2:41 am
I am sure there would be some fineprint thing about gas sealing for exhaust that they could get you on, on a ute you dont need a tailgate though
while they may not be able to ping you for it it would make for good attractant for then to take a look at you
Post Posted: Mon Nov 19, 2007 3:07 am
I Thought it was law for Side walled utes must have a tail gate??
Or else Subaru would have been able to bring out the Brumby replacement but were knocked back because it had a Rubber Latice like tail gate?
Post Posted: Mon Nov 19, 2007 5:46 pm
There was an eastern states bloke on the New Inventors a few weeks (months?) ago who had developed an add on thing like this for utes that extended the tray, by laying down the tailgate. I would imagine he must have looked into the legalities of it and wouldn't have continued if it wasn't going to be legal.
Mark.
Post Posted: Mon Nov 19, 2007 10:26 pm
I wouldnt worry about it. Make sure it looks neat. what is the worst that could happen.
[IMG]http://img.photobucket.com/albums/v711/richmo
Post Posted: Mon Nov 19, 2007 11:21 pm
I think you'll find it has a tailgate
Post Posted: Mon Nov 19, 2007 11:47 pm
They do me for a roady and pick the no sway bar, seats bolted through the ground, tyres bigger than 2"over standed, more than 2" suspension lift, motor doesn't have the same engine number as the rego(Havn't been to vic roads to change it :oops: sence putting the new one in 2 yearts ago!) The list go's on!
This is what i mean!
I do like that more but this is the other option!
Post Posted: Mon Nov 19, 2007 11:48 pm
Ah yeah thakns for the points guys i will take it into consideration.... 8)
Obviously i would take all the seals and latch and stuff off!
Post Posted: Mon Nov 19, 2007 11:52 pm
is it a 2 seater? can you seal under the marias back bit and get em to change the body type to ute?
Post Posted: Tue Nov 20, 2007 12:51 am
PLans have changed a little!
But Royce i'm planing on making a frame and sheet metaling that bottom bit off! 8)
I'm going to comine the both! Mount the spare there and cut the door around it! In vic it's illegal top have no tail gate in case of fumes or some crap! :? SO them combined should be awsome!
Any one see any problems with that idea? No one can steal my spare then either! 8)
Post Posted: Tue Nov 20, 2007 1:02 am
hehe well I guess you still have a tailgate :)
Post Posted: Tue Nov 20, 2007 9:49 pm
Yep and the style i want!
Should be awsome! 8)
Post Posted: Wed Nov 21, 2007 2:44 am
:o
Post Posted: Wed Nov 21, 2007 8:58 pm
want33s wrote:
Don't bother making a new wall for the back of the cab... Just get another tailgate, trim it down and weld it in. It will look better and already has a nice lip with press studs to clip your back window to. :D
Didn't think of that!
BUT there press studs not those clip thing's and cutting the door would be harder then making a steel frame and sheet metal it? Wouldn't it?
By the way welcome.... 8)
Users browsing this forum: No registered users and 64 guests
