It is currently Sat Nov 14, 2026 11:19 am
Post Posted: Tue Nov 27, 2007 2:34 pm
Was just browsing ebay (as you do :wink: ) and noticed this add:
Ebay GV Diff
The bit that grabbed my attention was this: Steel casing out of Grand Vitara with welded 4.3 centre.
If my thinking is correct - this would mean that you would only need to add manual hubs, and you would have a budget locker in the front when in 4wd...
Pros and Cons of this setup?
Post Posted: Tue Nov 27, 2007 2:57 pm
yes to being a locker, you can unlock the hubs to get your steering back when you dont need the locker, though times like on the beach when you want 4wd but dont want a locker they are very annoying and make steering through windy sand tracks difficult
on a side note, I know of a conglomerate :wink: pretty set to bid big on that item, the welded bit wont be required and you dont need the steel parts so perhaps a deal could be made :wink:
Post Posted: Tue Nov 27, 2007 11:31 pm
Looks like there are a few people I know looking at this as well. I'm happy to go 1/2s in the sale if anyone wants as I only want both cv's. Max I will go is $100ish. :-)
Post Posted: Wed Nov 28, 2007 1:25 pm
OK - unless its pretty cheap :wink: its probably not worth me grabbing the centre, as most of my off roading is on Stradbroke/Moreton - not as much time spent with wheels off the ground....
but at the right price......
I guess would also be more chance of blowing CV's due to the extra strain? Or not a common problem?
Post Posted: Wed Nov 28, 2007 1:39 pm
theres many different schools of thought about that, I think there is less chance as you can go a bit slower as you always have drive if a wheel is on the ground, with an open diff you tend to be getting a bit of a run up to clear obstacles and its the free spinning wheel smacking the ground again that pops them
though then you get into harder spots with a locker and can put a lot of drive through one CV and cause it to go bang
Post Posted: Sun Dec 02, 2007 9:20 pm
hard to imagine how a massive powered 1.3l can do damage like that isnt it but I have seen them snap from the "run-up" and wheels bouncing theory!
Users browsing this forum: Google [Bot] and 57 guests
