It is currently Sat Oct 17, 2026 3:40 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 8:41 am
Hi fellas,
I'm in the market for some fully-sic gauges for my new big-block Baleno motor :lol:
I had some aftermarket gauges hooked up to the old Sierra engine, but I broke the temp sender and couldn't get the oil pressure sender out of the old block.
Can anyone recommend some good oil pressure and engine temp gauges for a G16B?
:P
Vehicle: 2018 DMAX
Post Posted: Wed Sep 29, 2010 9:10 am
Repco has 2" gauges for $30 at the moment. If that sale is on down your way. I getting some of these tomorrow. Or supercheap has 25% off calibre gauges, $52 for water and oil guages.
Post Posted: Wed Sep 29, 2010 9:55 am
Autometer gauges are good quality but a little pricy
Post Posted: Wed Sep 29, 2010 10:01 am
speco are good, i don't trust vdo i had them and when i put the clutch in the temp would change
Post Posted: Wed Sep 29, 2010 10:17 am
x2 speco. love mine!
:lol: I have heard of that, never seen it tho.. :lol: :lol:
Should be fine for auto's then??? :P
Post Posted: Wed Sep 29, 2010 10:30 am
X2.
I have $3k worth for cammo 8O Thats only 7 or 8 guages :?
Post Posted: Wed Sep 29, 2010 10:31 am
X2.
:P Does it go yet??? :P
Post Posted: Wed Sep 29, 2010 10:33 am
steak_knife wrote:
X2.
Only in my dreams :lol:
Post Posted: Wed Sep 29, 2010 10:41 am
u must have a active imagination then mrfat
Post Posted: Wed Sep 29, 2010 10:42 am
So must you. We're still yet to see the mythical creature you call a girl friend :lol: :lol:
Post Posted: Wed Sep 29, 2010 11:28 am
I run Speco gauges in zook, but the bastards get moisture behind the lenses and the water temp has already been warrantied once, and now its reading too high again.
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 11:35 am
What sort of temperature range should I be looking for? The last one I had barely moved, even when the engine was working really hard.
Is the best place for the oil pressure sensor where the stock one is? Or can I put it somewhere else so I still have the dash light?
Post Posted: Wed Sep 29, 2010 11:53 am
Temp readings will vary with the location of the sensor - in the normal location (under the thermostat) look for 80~100 area (175~212).
For oil pressure - on a 1.3 there should be a second port just to the left and above the oil pressure switch, you can use that if you can get the plug out, or you can use a T and connect it to the oil pressure port.
If you're using mechanical gauges (ie not electric) toss the nylon line that comes with the gauge and get yourself some 1/8 copper - mount the T somewhere secure and wind a couple of loops in the copper line between the T and the engine to allow for engine movement & vibration.
Post Posted: Thu Sep 30, 2010 8:54 am
[u]
If you're using mechanical gauges (ie not electric) toss the nylon line that comes with rhe gauge and get yourself some 1/8 copper - mount the T somewhere secure and wind a couple of loops in the copper line between the T and the engine to allow for engine movement & vibration.
NEVER do this! it puts way to much leverage on the nipple going into the block. how do i know? been there done that twise!
first time was brass it broke off. 2nd time i used a steel nipple and that broke. i fixed this problem by getting a hose made up and mounted the sensoros on the body. never had a problem.
temp, mine would run at 85c all day everyday, on the beach in summer 85c, driving on a winters night 85c.
i would only use autometer gauges, after all you will fine them in 99% of race cars ect
only pic i could find
ideas for mounting
Post Posted: Thu Sep 30, 2010 10:07 am
I have used a T piece setup for oil pressure for a couple of years now, works fine.
Post Posted: Thu Sep 30, 2010 10:18 am
well it didnt work for me, and i would rather not take that risk again
Post Posted: Thu Sep 30, 2010 12:35 pm
brendan wrote:
[u]
Read the damn post will ya - doesn't it say to mount the T somewhere secure and wind a couple of loops in the copper line to allow for engine movement?
Now - be honest - did you do THAT? Or did you just bung a nipple into the block and screw the T onto the nipple?
If you mount a brass T directly to the block and then hang a honking great sender on the end, the chances of the brass nipple (between the T and the block) fatiguing & breaking because of the vibration are pretty good - as you already found out.
Feel free to use a hose, but if you do either use braided stainless steel or run a ground wire between the T and the chassis or the oil pressure light won't work.
Post Posted: Fri Oct 01, 2010 5:34 am
fordem wrote:
brendan wrote:
[u]
your post wasnt very clear hence i added my opinion
Post Posted: Thu Jul 28, 2011 12:32 am
sorry for the thread dig but just want some info on which water temp gauges to buy? Mechanical or Electrical and also how do you install them?
I want to install a water temp and oil temp in my sierra 1.3 but never done it before?
Any help will be much appreciated?
Post Posted: Thu Jul 28, 2011 12:59 am
Electrical.
Wire it to come on with the ignition and you will need a temp sender hooked up somewhere in the system before the radiator.
Post Posted: Thu Jul 28, 2011 1:20 am
some flashy digital gauges, although our location wouldnt suit most road cars as it uses the air vents
Post Posted: Thu Jul 28, 2011 3:05 am
How do the Calibre gauges go, are they accurate? I'm very wary of SuperCrapAuto branded products.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Jul 28, 2011 3:13 am
I have the same gauges in my zook. Haven't had an issue and they've been through some solid wheeling in the past 6months. Would buy them again.
Post Posted: Thu Jul 28, 2011 3:28 am
quality has improved leaps and bounds, for example the tools are sourced from the same mob as stanley
Post Posted: Thu Jul 28, 2011 3:40 am
Calibre is a decent brand.
SCA us what you dont want.
Post Posted: Thu Jul 28, 2011 4:04 am
bit like the 5" tacho? :lol:
Post Posted: Thu Jul 28, 2011 4:44 am
That may be so, but from my experience with alot of stanley products ( hand tools mainly) their quality has dropped significantly in the past 5 or 6 years.
Post Posted: Thu Jul 28, 2011 5:05 am
for the average guy they are fine, they have a lifetime warranty
if i was buying work tools though id spend the coin on the better brands
Post Posted: Thu Jul 28, 2011 5:17 am
Life time warranty doesn't mean shit to me. When the crappy casting of your cheap tools costs you weeks off work becuase it snapped applying moderate tension to a bolt, resulting in the fractured tool imbedding itself into your hand you'll learn very quickly that cheap tools with a life time warranty REALLY aren't worth it.
Just my 2 cents. :wink:
Anywho, I've never used the calibre guages, but they look a little too cheap/ rice for my liking. Same as the 'Drift' brand from Autobarn.
Autometer still make the best guages IMO. :wink:
Users browsing this forum: Google [Bot] and 203 guests
