It is currently Sat Nov 14, 2026 8:45 am
Post Posted: Thu Dec 13, 2007 6:58 pm
I have just purchased a 91' Suzuki Vitara and want to lift it urgently!!
Would I Be able to fit TWO Inch Lift Springs (King springs) with Spring Spacers without causing any problems???
Urgent replies would be appreicated!!!
Thanks :D
Post Posted: Thu Dec 13, 2007 7:29 pm
yes you can, you can shove 6" of spacer into it if you want
BUT
it will throw the front end out, severly limit your suspension travel and make CV's easier to break
over 2" you will need camber pins to get your wheel alingment back, over 3" you really shoudl look at teh calmini arms and drop brackets
Post Posted: Thu Dec 13, 2007 8:22 pm
Ill be using 40 mm springs 30 mm spring spacers in rear 15 mm in front!
Where do u get the camber pins from mate???
Post Posted: Thu Dec 13, 2007 8:54 pm
pedders is pretty good for them
Post Posted: Thu Dec 13, 2007 9:17 pm
And where are you getting the spacers from????? :wink:
Hint look at the bottom of my sign :wink:
Post Posted: Thu Dec 13, 2007 9:23 pm
How much mate?? Live in perth!
Post Posted: Fri Dec 14, 2007 12:07 am
PM BlairKerr :-)
Users browsing this forum: No registered users and 73 guests
