It is currently Mon Oct 19, 2026 5:25 pm
Post Posted: Tue Oct 26, 2010 12:18 am
Can any one tell me if machining down the locating ridge on the back face of a stub axle will cause it to be weakened,
basically in this pic the diameter is around 90mm and i need it to be 70mm
they are hardened so it will be "fun" to lathe it down but i just want to make sure that the strength will still be where it needs to be.
Post Posted: Tue Oct 26, 2010 6:48 am
I'm going with yes, it will weaken it
Post Posted: Tue Oct 26, 2010 6:50 am
& your going to get it case hardened again, can't you find somting more suited??
Or have it made??
Post Posted: Tue Oct 26, 2010 6:51 am
not really, suppose i would have it hardened again
Post Posted: Tue Oct 26, 2010 6:53 am
you would be lucky to get 100km out of it if you didn't..
Is this for the floating??
Post Posted: Tue Oct 26, 2010 6:56 am
why not use a sierra one?
Post Posted: Tue Oct 26, 2010 6:57 am
yeah, either that or i cut some adapter plates, but they will only be mild steel any way
im not even sure that that part of the stub will matter if its weaker
Users browsing this forum: Google [Bot] and 238 guests
