http://auszookers.com/forum/
Transfer removal
http://auszookers.com/forum/viewtopic.php?f=5&t=15945
Author:  maloo11 [ Fri Oct 15, 2010 5:38 am ]
Post subject:  Transfer removal
In the process of taking out my transfer case (never done before). How do you get the small metal clamp off at the bottom of the lever? Does it split with a screwdriver?
Author:  Ben_Sierra [ Fri Oct 15, 2010 5:47 am ]
Post subject:  Re: Transfer removal
Push down and twist.
Author:  Gwagensteve [ Fri Oct 15, 2010 5:57 am ]
Are you talking about the hose clamp thingy that holds the rubber boot on? if so, there is a little tab folded over that holds it tight. Find the tab and open it up with a screwdriver. (It's kind of a like a compressed Z shape and unfolds)
Author:  maloo11 [ Fri Oct 15, 2010 5:58 am ]
Ok. thanks
Author:  Gwagensteve [ Fri Oct 15, 2010 5:59 am ]
See my post above.
Author:  maloo11 [ Fri Oct 15, 2010 6:27 am ]
Ok guys, my shift lever aint moving. Boot is off and i can see the spring, everything done according to haynes manual, but the lever wont budge. i push down and turn and NOTHING. Does it need a helping hand with the hammer?
Author:  christover1 [ Fri Oct 15, 2010 6:33 am ]
I always left my stick on, when dropping t-case. It was easier to get at stick on the floor.
But make sure you push and twist on the bottom piece, not the stick itself
Author:  christover1 [ Fri Oct 15, 2010 6:41 am ]
See the bit in pic, will give you an idea how it comes out.
Same as the bit on a single stick, but didn't couldn't find a picture
Author:  maloo11 [ Fri Oct 15, 2010 6:46 am ]
Got it. Thanks for your help.
Author:  Hotshot993 [ Mon Sep 19, 2011 3:55 am ]
Hey my transfer lever is stuck in neutral. Trying to get that spring loaded thing off. I push down, turn anti clockwise. Should pop up all the way and stick should just pull out or what do I do. Been at it for last 30mins trying to twist it and get the thing off but nothing so far. Also it's really hard to twist that spring loaded thing.
Author:  stockman [ Mon Sep 19, 2011 3:57 am ]
Just make sure you are pushing down hard enough.
Also when taking the case out I find it easier to leave the stick in and put it into 4x4 low.
Author:  Hotshot993 [ Mon Sep 19, 2011 4:01 am ]
I'm not taking the case out. Just need the stick out. And I got it turned a bit and it still won't pop up:/
Author:  Hotshot993 [ Mon Sep 19, 2011 4:07 am ]
It like got to a certain part and t won't go any further. But won't pop up either
Author:  Hotshot993 [ Mon Sep 19, 2011 4:11 am ]
Got it thanks. Just the spring wasn't pushing it up it was stuck.
Author:  stockman [ Mon Sep 19, 2011 4:19 am ]
That was for the other guy.
Use a couple of flat head screwdrivers.
Author:  Hotshot993 [ Mon Sep 19, 2011 5:06 am ]
The problem is that it's like jammed between two gears and I need to try and line up the two gaps inside the transfer case so I get get the lever in there. If you kind of get what I mean:/
