It is currently Sat Oct 10, 2026 1:57 am
Post Posted: Sun Oct 17, 2010 7:13 am
Im thinking of doing a 50mm body lift to the new GV but cannot find a kit for it anywhere. It is a non airbag model so its allowed.
Who has done one and what kit did you use and from where did you get it.
It all looks quite simple to do but what have others done to sort out the steering.
Let me know if there are any things i need to look out for.
Post Posted: Sun Oct 17, 2010 7:17 am
http://auszookers.com/index.php?name=Fo ... ht=humzuki
He did it.. :P
Post Posted: Sun Oct 17, 2010 7:59 pm
You can do a 1" bodylift without any real mods and it can be put back if you need to.
Just get some blocks made up 8) and you still use the factory bolts and studs in the body.
Post Posted: Sun Oct 17, 2010 8:40 pm
What about Just_cruizin ?
Post Posted: Mon Oct 18, 2010 7:16 am
Was going to mention him, the vit lwb one should work for a Gv..
Post Posted: Mon Oct 18, 2010 7:25 am
There is a kit from Lowrange that is said to fit the GV. Might just get that and see how it fits and fix any problems as they happen.
Post Posted: Mon Oct 18, 2010 7:58 am
I used Just_Cruizin and i had to modify it to fit, then I had to work out my own solution to the steering problem.
It may be worth talking with him as hopefully he now makes one too fit...including steering spacers.
If your not breaking shit, try harder!!!
Post Posted: Mon Oct 18, 2010 8:53 am
i made a mistake.. body lift kit is from rockyroad.
http://www.rocky-road.com/kickbodylift.html
Comes with brake extensions and steering ext.
Post Posted: Mon Oct 18, 2010 9:05 am
that steering is laughable!
this is what you need.
Post Posted: Mon Oct 18, 2010 9:59 am
I'm amazed at what is available for these cars now.
I only did mine 3 years ago and nothing was around. I had to search the globe even just for basic stuff.
Vehicle: 2004 SQ625 GV
Post Posted: Tue Oct 19, 2010 3:25 am
What did you do about the strut brace?
Post Posted: Tue Oct 19, 2010 3:38 am
Isn't that a bit too 'bling' for a Zook?
Post Posted: Tue Oct 19, 2010 4:49 am
Im guessing you made that yourself? can ya make me one...PLEASE. 50mm
Post Posted: Thu Oct 21, 2010 8:54 am
What have people done with the front strut setup. Is it as easy as just fitting a strut top extension, the type that just screws onto the strut shaft or is there more to it?
like this
http://www.bits4vits.co.uk/store/images ... trtSp1.JPG
Users browsing this forum: No registered users and 215 guests
