| fitting Wt flares to NT http://auszookers.com/forum/viewtopic.php?f=5&t=16056 |
| Author: | DR_JOSH [ Tue Oct 19, 2010 9:28 am ] |
| Post subject: | fitting Wt flares to NT |
So I finally have some decent WT flares in my possession and looking put them on my tintop. Question is are the WT mounting brackets needed for fitting or can the NT little lip mountings be used for the job? I would just go have a look for myself but I don't have my car in my possession currently |
| Author: | 11_evl [ Tue Oct 19, 2010 9:45 am ] |
| Post subject: | Re: fitting Wt flares to NT |
just rivit the WT mounting brackets to your guards |
| Author: | DR_JOSH [ Tue Oct 19, 2010 9:49 am ] |
I don't have WT mounting brackets, hence the question. Getting any sierra parts down this way is a pain in the ass too |
| Author: | steak_knife [ Tue Oct 19, 2010 10:00 am ] |
Make up some small tag's that bolt to the w/t flare & screw em to the n/t bracket's on the car.. I'll go get some pic's, just skimmed through the pic's I have & couldn't find any.. |
| Author: | steak_knife [ Tue Oct 19, 2010 10:08 am ] |
I just bolted the tag's to the flare, lined em up on the car & used roofing screw's through the n/t bracket's, have had the car leaning on em, plenty strong enough.. |
| Author: | Rhino [ Tue Oct 19, 2010 10:44 am ] |
DR_JOSH wrote: I don't have WT mounting brackets, hence the question. Getting any sierra parts down this way is a pain in the ass too
I got a set of mounting brackets here i dont need... You organise and pay postage and there all yours. |
| Author: | JrZook [ Tue Oct 19, 2010 10:40 pm ] |
steak_knife wrote: Make up some small tag's that bolt to the w/t flare & screw em to the n/t bracket's on the car..
I'll go get some pic's, just skimmed through the pic's I have & couldn't find any.. Pics of the pancake flare!!! |
| Author: | Jccck [ Tue Oct 19, 2010 11:43 pm ] |
steak_knife wrote: :P
I just bolted the tag's to the flare, lined em up on the car & used roofing screw's through the n/t bracket's, have had the car leaning on em, plenty strong enough.. Stekky techscrewed his flares on! |
| Author: | sickzuk1 [ Tue Oct 19, 2010 11:58 pm ] |
Hahaha.. Is there something wrong with that? D: Tech screws are amazing! |
| Author: | Jccck [ Wed Oct 20, 2010 12:09 am ] |
sickzuk1 wrote: Hahaha.. Is there something wrong with that? D: Tech screws are amazing!
Yeah they're tops haha.. But they're like chocolate really. So good, but don't go too crazy lol Proposing namechange for Stekky.. "Stekscrews" |
| Author: | DR_JOSH [ Wed Oct 20, 2010 12:11 am ] |
Cheers Stekky, I'll just do something like that but maybe a little different as my flares are the plastic ones. |
| Author: | Jccck [ Wed Oct 20, 2010 12:15 am ] |
DR_JOSH wrote: Cheers Stekky, I'll just do something like that but maybe a little different as my flares are the plastic ones.
Get some 1mm thick gal/zinc angle 25x25 or somethin .. Cut slits every inch or so along one edge so it can be bent and wraps around the line of your wheel arch on the outside Rivet it into the guard, then tech screw/rivet the plastic flare on the underside to mimic the standard fitment This is how i was going to mount metal WT flares to mine, would've worked a treat.. And should be ok for the plastic versions |
| Author: | Fatzook [ Wed Oct 20, 2010 12:50 am ] |
Jccck wrote: Get some 1mm thick gal/zinc angle 25x25 or somethin .. Cut slits every inch or so along one edge so it can be bent and wraps around the line of your wheel arch on the outside
Rivet it into the guard, then tech screw/rivet the plastic flare on the underside to mimic the standard fitment Or get the angle rolled at your local fabrication shop. Easier, neater, and you won't have 7000 cuts in the angle where rust can form. |
| Author: | JrZook [ Wed Oct 20, 2010 12:51 am ] |
Well here are some pics of my plastic flare mounting system to give you an idea. Note I do have a virtual lift. These are a few brackets I made to hold the drivers front flare on. I used 32x3mm ally plate, cut and bent to fit the guard and flare. Three mounts per flare. Used M6x16mm stainless nuts and bolts to hold everything together and to ensure no rust!!
Front mount
Center mount |
| Author: | steak_knife [ Wed Oct 20, 2010 6:37 am ] |
