It is currently Wed Oct 07, 2026 6:53 am
Post Posted: Wed Oct 20, 2010 2:41 am
G'day guys
I have recently come across a vitara that has not been started in about 18 months. It starts pretty easy but is idling at a touch under 3000rpm. Once the engine is warm it still does not drop down.
Check out the attached picture. When i press down on the thing that the red arrow is pointing at it drops back down to a good idle but once i let go it spings back and start idleing high again.
any ideas what i could do to get it running properly
[IMG]http://img.photobucket.com/albums/v711/richmo
Post Posted: Wed Oct 20, 2010 2:56 am
thats the choke pulled on massivley, that bit you push on, further down find the cannister with 2 water hoses going into it and and an adjsuter screw connected to that same piece, turn the screw till it opens that top flap and the revs drop
Post Posted: Wed Oct 20, 2010 4:52 am
Pulled 2 hoses off and made sure they were not blocked. Seems like there is a piston that pushes out to turn the choke off. Looks to be seized. Any ideas on how to loosen it up again?
Users browsing this forum: Google [Bot] and 189 guests
