It is currently Thu Oct 15, 2026 1:37 am
Post Posted: Fri Oct 22, 2010 4:24 am
my 95 sierra is making a fairly loud tapping noise that appears to be coming from the exhaust manifol would this be a sign of the manifold being cracked i cannot see the manifold as the heat shield is still attatched and all the bolts are rusted up
Post Posted: Sat Oct 23, 2010 6:53 am
if its like a tapping or a ticking sort of noise it will more than likely be your manifold gasket blown out
Post Posted: Sat Oct 23, 2010 6:57 am
Or the wire mesh gasket that sits between the manifold and the downpipe. They can crack or get mashed up causing a leak. Pretty common.
I don't think sierra manifolds are prone to cracking to the point they audibly leak.
I know G16A Vitara manfolids are known to fall apart.
Post Posted: Sat Oct 23, 2010 7:01 am
get some redex engine treatment, follow the instructions about dribbling it down the carby, all leaks will stand out like dogs balls after that :)
Users browsing this forum: Google [Bot] and 1026 guests
