| switches into top of gear box http://auszookers.com/forum/viewtopic.php?f=5&t=16097 |
| Author: | needmorelift [ Wed Oct 20, 2010 12:01 pm ] |
| Post subject: | switches into top of gear box |
howdy guys how is one able to determine which is the reverse switch for the gearbox? basically i've got the holes plugged up but not connected to any wires cos i don't know where they go :S i know the reverse is sposed to have a big circle clip but the ones on my lwb are small rectangle clips |
| Author: | 31zook [ Wed Oct 20, 2010 6:26 pm ] |
| Post subject: | Re: switches into top of gear box |
stand behind the box and it's on the far left. |
| Author: | royce [ Wed Oct 20, 2010 7:30 pm ] |
One with the red and and yellow wires |
| Author: | needmorelift [ Wed Oct 20, 2010 8:36 pm ] |
from behind the engine. which one? also what are the others for?
Uploaded with ImageShack.us cheers |
| Author: | 303zuke [ Thu Oct 21, 2010 4:31 am ] |
needmorelift wrote: how is one able to determine which is the reverse switch?
Have a think about what the gear lever does and you can work out which is the switch. When you move the gear lever into Rev, you move it across to the right and back. Because the lever pivots in a seat, you are actually moving the far LEFT shift RAIL forward. The end of this shift rail contacts the end of the switch. In your pic, it's the switch with the white top. Over the years, Suzuki has used different plug ends and wire traces on these switches, but the position has remained the same. The other 2 switches operate Vacuum Switching Valves in 4th and 5th gear for emissions and EGR purposes. |
| Author: | needmorelift [ Thu Oct 21, 2010 6:10 am ] |
legend mate cheers |
