It is currently Fri Oct 09, 2026 8:23 pm
Post Posted: Wed Oct 20, 2010 6:15 pm
I have three questions.
1: I have found some 225/75/16 muddies on steel GV rims with tubes for around $800. I did the maths and found that they are 29.3" tall. 235/75/15 are 28.9" and I have been told that they fit on a stock sierra. Does that mean that the 225/75/16 will fit?
2: When going through deeper water I have found that my fan likes to chew my radiator :lol: I can't remember who it was but someone said a vitara viscous fan fits. Would they stop turning in water?
3: Done my diff breathers and want to do gbox and tbox but I didn't know whether you need to remove them to fit breathers or not. Does someone have pictures of the stock breather location and can tell me the best way to fit breathers to them?
P.S. I did search :P
Post Posted: Wed Oct 20, 2010 6:30 pm
yes a 225 will fit a stock sierra rim.
just get a thermo and hook up a switch.
and you could do the tcase in the car but a doubt the gbox would be possible.
Post Posted: Wed Oct 20, 2010 7:11 pm
2: When going through deeper water I have found that my fan likes to chew my radiator Laughing I can't remember who it was but someone said a vitara viscous fan fits. Would they stop turning in water?
if ur fan is hitting ur radiator .. u may have a busted engine mount (most likely the left side )...as i had the same problem .. and snapped a few fins off after hitting a decent puddle ..so u might wanna check ur mounts ;)
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Wed Oct 20, 2010 7:37 pm
if you drive through a lot of water just fit a thermo fan. i have mine on a temp
switch and also a switch on the dash to turn it off when necessary.
it is possible to fit a breather to a transfer case in the car but it is very fiddly, i
wouldn't bother unless you are getting water in them
i dunno for sure but the gv rims will fit however i think that the rim offset will suck a lot.
Post Posted: Wed Oct 20, 2010 7:38 pm
A: I'm talking 16's here
B: can't be bothered looking for one.
C: ok.
Post Posted: Wed Oct 20, 2010 7:39 pm
OK will look at the mount. :)
Post Posted: Wed Oct 20, 2010 7:53 pm
I have seen them on a sierra before as the poms use them and they stick pot futher than the stockos.
Users browsing this forum: Google [Bot] and 162 guests
