| Author |
Message |
sleeperzook
Joined: Mon Jul 06, 2009 11:30 pm Posts: 208 Location: Adelaide
 Posted: Thu Oct 21, 2010 6:29 am |
Ok so yesterday I noticed my zook has a vibration that gets reasonably noticeable to me at around 80km/h. I got my wheels balanced today (they were way out, one my 90grams!!) but it wasnt the source.
I dont drive it often but I did put some 2" OME springs in 2 nights ago and I reckon it started then. The tyre guy suggested it could be tread pattern and I never noticed till now because I have new, stiffer shocks. I'm only running BFG 235/75/15 A/T's, so I dont think so. I'm thinking its the extra uni angle with the increased lift and maybe the fact it got a flogging for 3hrs on a dyno yesterday. I'm guessing the uni's are running on a spot they previously didnt get to? Is this common and is it likely to fail soon, because I'm taking it on a trip tomorrow, but I'm a feather foot.
Any other ideas guys??
PS. I have a 2" T/case lift also.
lukes_89
Joined: Fri Sep 25, 2009 11:30 pm Posts: 1204 Location: sunshine coast
 Posted: Thu Oct 21, 2010 8:08 am |
id say uni joint mine done the same thing but they were absolutley rooted
sleeperzook
 Posted: Thu Oct 21, 2010 9:20 am |
lukes_89 wrote: id say uni joint mine done the same thing but they were absolutley rooted
Are they a hard fix? I mean I've got no time to do them before I leave but if I got a couple could I change them pretty easy when I get to where I'm going?
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Thu Oct 21, 2010 9:30 am |
you'll need a press to change your uni's. the extra vibrations can be terrible on your drivetrain, when my uni's went it blew front and rear pinion seals.
sleeperzook
 Posted: Thu Oct 21, 2010 9:40 am |
Zook_Fan wrote: you'll need a press to change your uni's. the extra vibrations can be terrible on your drivetrain, when my uni's went it blew front and rear pinion seals.
Didnt want to hear that  lol
alien
 Posted: Thu Oct 21, 2010 12:10 pm |
something else - i had a vibration once that i couldnt find - turned out to be a busted engine mount =P
dm90
Joined: Sun Nov 29, 2009 10:30 pm Posts: 4349 Location: Perth
 Posted: Thu Oct 21, 2010 2:45 pm |
alien wrote: something else - i had a vibration once that i couldnt find - turned out to be a busted engine mount =P
x2
except it was on my old camry
rick1970
Joined: Sun Jul 04, 2010 9:39 pm Posts: 303 Location: Dungowan
 Posted: Fri Oct 22, 2010 7:32 am |
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Oct 22, 2010 7:52 am |
you will need to press them out, but a brass punch will get them in, just make sure when your done doing uni's to tap the shaft while it's laying on the ground to release a bit of the uneven pressure off the needle bearings, it only gets these strains because it's being all pressed together nice and firm....
Jccck
 Posted: Fri Oct 22, 2010 8:01 am |
31zook wrote: you will need to press them out, but a brass punch will get them in, just make sure when your done doing uni's to tap the shaft while it's laying on the ground to release a bit of the uneven pressure off the needle bearings, it only gets these strains because it's being all pressed together nice and firm....
Definantly don't need a press to get them out..
Also what angle are your uni joints at, if they run straight it can cause bad vibes
They have to run at atleast a small angle
rick1970
 Posted: Fri Oct 22, 2010 8:13 am |
Jccck wrote: 31zook wrote: you will need to press them out, but a brass punch will get them in, just make sure when your done doing uni's to tap the shaft while it's laying on the ground to release a bit of the uneven pressure off the needle bearings, it only gets these strains because it's being all pressed together nice and firm.... Definantly don't need a press to get them out..
Yeah, never needed a press for uni's before.
Shit, you can even change them on the side of the road with a few basic tools if your really stuck.
